Loading...
Pages: 1 ... 5 6 [7]   Go Down
Author Topic: Interest in overhauling the IDE user interface?  (Read 11376 times)
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Hi Josh,
I downloaded the Windows version and got this error
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
0
Offline Offline
Newbie
Arduino rocks
View Profile
What version of windows are you running?
Hi Josh,
______
Rob
Logged
Offline Offline
Tesla Member
View Profile
WWW
Vista.
______
Rob
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hmm.  32 or 64 bit?
Logged
Offline Offline
Tesla Member
View Profile
WWW
Sorry, 32-bit.
______
Rob
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Sorry, 32-bit.
______
Rob
Okay. That explains it. I'm currently only building the 64bit version. I'll work on a 32bit as well.
In the meantime, I've just pushed out a new build which fixes a ton of bugs and also remembers the set of open sketches between runs.
Logged
Offline Offline
Tesla Member
View Profile
WWW
OK, thanks.
______
Rob
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I've published a 32bit version, along with a bunch of updates.  It's added to the build system so now we will always get both versions.  Please test it out here:
http://hudson.joshy.org:9001/job/ArduinoX/lastSuccessfulBuild/artifact/dist/
Logged
Offline Offline
Tesla Member
View Profile
WWW
Trying to compile "blink"
Code:
starting compile
assembling sketch in directory: C:\ArduinoX\win
using temp dir: C:\Users\Rob\AppData\Local\Temp\josharduinobuild1498449018706449586.tmp
generating C/C++ file: C:\Users\Rob\AppData\Local\Temp\josharduinobuild1498449018706449586.tmp\.cpp
error!
null
java.lang.NullPointerException
at com.joshondesign.arduino.common.CompileTask.assemble(CompileTask.java:130)
at com.joshondesign.arduinox.Actions$2$1.run(Actions.java:74)
at java.lang.Thread.run(Unknown Source)
Vista, 32-bit, Arduino 1.0.2 I guess but I also have 1.5 installed, how does it know which one to use?
Note the CPP filename.
______
Rob
« Last Edit: November 26, 2012, 11:19:48 am by Graynomad » Logged
Offline Offline
Newbie
I'm glad I bought an Arduino Leonardo
View Profile
sounds like you all are updating the Arduino IDE now and taking suggestions?
Wish list suggestions...
- Option for numbered lines, maybe have the background for the number light gray
- Search option in "Edit" add "Find and Replace" with check able options to replace all or ask to replace.
- Option to drag & drop selected text
- Option to ask to save the sketch if it was edited before Uploading or Require the sketch to be saved before uploading
- Change font type
FYI: I'm using 1.0.1 on win7 64-bit
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hmm. I can't recreate this error.  Does it happen with other sketches too or just hte Blink sketch? Can you post the contents of the settings.txt in the sketch directory?
thanks.
Code:
starting compile
error!
null
______
Rob
Logged
Offline Offline
Tesla Member
View Profile
WWW
An empty sketch compiled OK. So I tried blink again and now it works. Go figure.
Note this line from the compile output
Quote
generating C/C++ file: C:\Users\Rob\AppData\Local\Temp\josharduinobuild1233808034218210217.tmp\test.cpp
it seems to be correct now.
Quote
Don't know if you need it any more but there is no settings.txt.
______
Rob
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Yeah, there probably won't be until you modify and save the sketch.  No worries. I'm glad it works for you now.
- J
Quote
Quote
______
Rob
Logged
Pages: 1 ... 5 6 [7]   Go Up
Print
Jump to:
