Topic: Interest in overhauling the IDE user interface? (Read 39368 times) previous topic - next topic
graynomad
Hi Josh,
I downloaded the Windows version and got this error
______
Rob
joshmarinacci
What version of windows are you running?
Hi Josh,
______
Rob
graynomad
joshmarinacci
graynomad
joshmarinacci
Sorry, 32-bit.
______
Rob
Okay. That explains it. I'm currently only building the 64bit version. I'll work on a 32bit as well.
In the meantime, I've just pushed out a new build which fixes a ton of bugs and also remembers the set of open sketches between runs.
graynomad
joshmarinacci
I've published a 32bit version, along with a bunch of updates.  It's added to the build system so now we will always get both versions.  Please test it out here:
http://hudson.joshy.org:9001/job/ArduinoX/lastSuccessfulBuild/artifact/dist/
graynomad
#98
Nov 26, 2012, 05:14 pm Last Edit: Nov 26, 2012, 05:19 pm by Graynomad Reason: 1
Trying to compile "blink"
starting compile
assembling sketch in directory: C:\ArduinoX\win
using temp dir: C:\Users\Rob\AppData\Local\Temp\josharduinobuild1498449018706449586.tmp
generating C/C++ file: C:\Users\Rob\AppData\Local\Temp\josharduinobuild1498449018706449586.tmp\.cpp
error!
null
java.lang.NullPointerException
at com.joshondesign.arduino.common.CompileTask.assemble(CompileTask.java:130)
at com.joshondesign.arduinox.Actions$2$1.run(Actions.java:74)
at java.lang.Thread.run(Unknown Source)
Vista, 32-bit, Arduino 1.0.2 I guess but I also have 1.5 installed, how does it know which one to use?
Note the CPP filename.
______
Rob
S_Flex
sounds like you all are updating the Arduino IDE now and taking suggestions?
Wish list suggestions...
- Option for numbered lines, maybe have the background for the number light gray
- Search option in "Edit" add "Find and Replace" with check able options to replace all or ask to replace.
- Option to drag & drop selected text
- Option to ask to save the sketch if it was edited before Uploading or Require the sketch to be saved before uploading
- Change font type
FYI: I'm using 1.0.1 on win7 64-bit
joshmarinacci
Hmm. I can't recreate this error.  Does it happen with other sketches too or just hte Blink sketch? Can you post the contents of the settings.txt in the sketch directory?
thanks.
starting compile
error!
null
______
Rob
graynomad
An empty sketch compiled OK. So I tried blink again and now it works. Go figure.
Note this line from the compile output
generating C/C++ file: C:\Users\Rob\AppData\Local\Temp\josharduinobuild1233808034218210217.tmp\test.cpp
it seems to be correct now.
Don't know if you need it any more but there is no settings.txt.
______
Rob
joshmarinacci
Yeah, there probably won't be until you modify and save the sketch.  No worries. I'm glad it works for you now.
- J
______
Rob
