Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: SainSmart 20 x 4 LCD wanting to use I2C from Arduino Uno  (Read 5258 times)
Málaga, Spain
Offline Offline
Edison Member
View Profile
WWW
Yes, there is no problem what so ever. Just create two objects (variables) initialising them correctly and they will work. I have use a chain of 4 devices: 2 lcds and keyboards.
Logged
Portland, Oregon
Offline Offline
Newbie
View Profile
I had same problem reported by others using the SainSmart examples and libraries.  Finally found this and followed Andrew's advice and now it works!  Must agree with displayed message.
Thanks guys!
Logged
Offline Offline
Newbie
View Profile
After blundering about the internet for a while trying to get this Sainsmart 2004 display working with help for their 'excellent documentation'  smiley-confuse, I stumbled on this thread.
 A few minutes and I was up & running.
Registered on the forum just to say thanks Andrew!
Logged
Offline Offline
Newbie
View Profile
Hello Guys,
marry christmas and sorry for my bad english but i got yesterday the SainSmart Mega 2560 with LCD2004 and Sensorshield V5.0. After assembling the boards, i started the I2C-Scanner but I didn't found a device! I'm 100% sure that my wire-connection is correct and the sensor-shield-board can't also be wrong mounted without destroying. After trying some libraries I decided to demount the sensor-shield and connecting the LCD2004 directly to the SainSmart (GND, 5V, SDA and SCL) and started the I2C-Scan again and got the address 0x3F (happy!!!).
My question is.... what could by my mistake by assembling the boards? Or is it neccessary to write more code to connect the sensor-shield-board?
Logged
Offline Offline
Newbie
View Profile
Hey everybody! Happy New Year! My new sainsmart 20x4 LCD showed up today and all I got was the LCD? No documentation and no cable for connecting it to the arduino. Could someone tell me what type of connector I need so I can make a cable? Thanks!
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
You will get a more reliable answer if you post a better description or a link to the actual device.
Don
Logged
Offline Offline
Newbie
View Profile
Haha, sorry. good call.
http://www.amazon.com/SainSmart-Serial-Module-Shield-Arduino/dp/B0080DYTZQ/ref=sr_1_2?ie=UTF8&qid=1357090534&sr=8-2&keywords=sainsmart+lcd+20x4
Logged
Dee Why NSW
Offline Offline
Full Member
View Profile
Happy new year.
I use LiquidCrystal_I2C.h. You could make up a cable using standard 0.1" 4 pin females, but I just tore off four conductors from a 40-way ribbon with females already included.
« Last Edit: January 02, 2013, 02:18:12 am by NickPyner » Logged
Offline Offline
Newbie
View Profile
The 40-way worked great. Thanks for the tip!
Logged
Offline Offline
Newbie
View Profile
Hey guys, finally got the sainsmart lcd2004 sheild wired up (5v,gnd, SDA(pin 20), SCL (pin 21)) into the mega2560. When I run the hello world code (which apprears in the examples section of the IDE) below (directly from the new LiquidCrystal v1.2.1) all it does is flash very dimly. If I unplug the SDA and SCL it lights up and is clearly getting power. Any ideas?
0x3F came from the I2C scanner program I ran. There are no errors compiling.
#include <Wire.h>
#define BACKLIGHT_PIN     21
LiquidCrystal_I2C lcd(0x3F);  // Set the LCD I2C address
//LiquidCrystal_I2C lcd(0x3F, BACKLIGHT_PIN, POSITIVE);  // Set the LCD I2C address
// Creat a set of new characters
const uint8_t charBitmap[][8] = {
   { 0xc, 0x12, 0x12, 0xc, 0, 0, 0, 0 },
   { 0x6, 0x9, 0x9, 0x6, 0, 0, 0, 0 },
   { 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0, 0x0 },
   { 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0, 0x0 },
   { 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0x0 },
   { 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0x0 },
   { 0x0, 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0x0 },
   { 0x0, 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0x0 }
   int charBitmapSize = (sizeof(charBitmap ) / sizeof (charBitmap[0]));
  // Switch on the backlight
  pinMode ( BACKLIGHT_PIN, OUTPUT );
  digitalWrite ( BACKLIGHT_PIN, HIGH );
  lcd.begin(20,4);               // initialize the lcd
    for ( int i = 0; i < charBitmapSize; i++ )
      lcd.createChar ( i, (uint8_t *)charBitmap );
  lcd.home ();                   // go home
  lcd.print("Hello, ARDUINO ");
  lcd.setCursor ( 0, 1 );        // go to the next line
  lcd.print (" FORUM - fm   ");
  delay ( 100000 );
   lcd.home ();
   // Do a little animation by writing to the same location
   for ( int i = 0; i < 4; i++ )
      for ( int j = 0; j < 20; j++ )
         lcd.print (char(random(7)));
   delay (2000);
Logged
Dee Why NSW
Offline Offline
Full Member
View Profile
We have the same library and the display should probably work the same. The display is disconcerting on start-up and you might think it is faulty. The light comes on and then goes goes off, then comes on fully operational.
Here is the start of a clock. Note that I don't define the backlight pin.
Code:
//Arduino 1.0+ Only
//Arduino 1.0+ Only
#include "Wire.h"
#define DS1307_ADDRESS 0x68
LiquidCrystal_I2C lcd(0x27,20,4);
void setup(){
  Wire.begin();
  lcd.init();
 lcd.clear();
      lcd.backlight();  //Backlight ON if under program control
      lcd.setCursor(0,0);
  // Print a message to the LCD.
 lcd.print("Today it is");
void loop(){
  printDate();
« Last Edit: January 03, 2013, 05:13:59 pm by NickPyner » Logged
Offline Offline
Newbie
View Profile
Thanks for the reply! I gave it shot but it did not work.
I changed this:
#include "Wire.h"
   to
#include <Wire.h>
The line below however now throws the error: invalid conversion from 'int' to 't_backlighPol'
I've been trying a bunch of different things and i can get the LCD to fully light and blink the cursor if the only thing in the loop is lcd.setCursor(X,Y); if I put anything else in the loop the LCD either does not illuminate or dims by 50+%.
Logged
Dee Why NSW
Offline Offline
Full Member
View Profile
I didn't realise I had "wire.h" and not <wire.h>. I can only conclude it makes no difference!
(EDIT)
I've changed it and it works the same.
Also Dafes looks the same as mine, except he is using 16x4 instead of 20x4. The backlight bit is the same.
« Last Edit: January 03, 2013, 07:07:42 pm by NickPyner » Logged
Offline Offline
Newbie
View Profile
Hi hopes this helps:
Code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,4);  // set the LCD address to 0x27 for a 16 chars and 4 line display
  // initialize serial communication at 9600 bits per second:
  lcd.init();                      // initialize the lcd
  lcd.backlight();
lcd.print("Test");
void Test()
  lcd.print("Test");
I'have tried this with the  followign  I2C Libary´s
http://www.exp-tech.de/service/library/2004%20LiquidCrystal_I2C.rar
http://www.exp-tech.de/service/library/LiquidCrystal_I2C2004V1.rar
Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
