Topic: Leonardo Question (Read 2334 times) previous topic - next topic
jefferson987
For simplicity, I made a video to ask my question:
http://www.youtube.com/watch?v=nXldtGzONus&feature=youtu.be
johnwasser
The question in the video is:
"LEDs are connected to most of the Arduino Leonardo pins. When I power up or reset some of the LEDs pulse for a few seconds (reportedly something the bootloader does).  Can I get rid of that and have it go straight to my sketch?  If so, how?"
cmiyc
jefferson987
Sorry, I thought posting a video would help facilitate the process, guess not. Thanks for posting the summary though, I really need to figure this out. I don't have a schematic but its really simple, just LEDS connected to pwm pins that fade on in succession. Here is the code I'm using:
int leds[] = {
  3,5,6,9,10,11,13};
int num = 7;
void init_leds(){
  for(int i = 0; i<num; i++){
    digitalWrite(leds[i],LOW);
    pinMode(leds[i], OUTPUT);
void FadeOutLeds(){
  for(int i = 155;i>0;i--){
    for(int j = 0;j<num;j++){
      analogWrite(leds[j],i);
    delay(80);
void FadeInLed(int theLed){
  for(int i = 0;i<256;i++){
    analogWrite(theLed,i);
    delay(20);
  // initialize the digital pins as an output.
  init_leds();
// the loop routine runs over and over again forever:
  for(int i = 0; i<num;i++){
    FadeInLed(leds[i]);
  delay(5000);               // wait for 5 seconds
  FadeOutLeds();
  delay(5000);
Im not certain a schematic would help anyway. Im not sure theres technically anything wrong, from what I've read about the Leonardo the bootloader takes 8 seconds to run which is exactly how long the first LEDs pulse for. I just need to know if theres a way to make them stop and have my project begin right away vs. having to wait 8 seconds before the above code is executed.
frank26080115
Modify the bootloader, or use an ISP programmer for all future programming.
jefferson987
Could you maybe explain that a little more? I'm a beginner. Is there a way I can accomplish that without any extra hardware?
jefferson987
Ah ha! After a little digging, I've found this:
When you upload a sketch, you're using the Arduino bootloader, a small program that has been loaded on to the microcontroller on your board. It allows you to upload code without using any additional hardware. The bootloader is active for a few seconds when the board resets; then it starts whichever sketch was most recently uploaded to the microcontroller. The bootloader will blink the on-board (pin 13) LED when it starts (i.e. when the board resets).
That explains the pulsing LED in the beginning. Im still not sure how to ditch the bootloader though...
jefferson987
Making some progress here... for what I've read I can use another Arduino to burn the bootloader using ISP, but in order to upload a sketch and overwrite the bootloader I would need to use an ICSP programmer. Is that correct? If I can use another Arduino to burn the bootloader can I also use it to burn a modified bootloader?
silasmoeckel
If you program it with another arduino or similar ISP based programmer there is no bootloader thus no blinking.  The downside is you will have to continue to use them until you put the boot loader back with one.  If you do not have or do not want to use another arduio a standalone programmer is a few bucks on ebay.  Personally I use a hacked version of the ebay one to also give me ttl serial have yet to find anybody selling those.
silasmoeckel
ISP and ISCP are pretty much interchangeable.  If you can burn the boot loader you can burn a sketch there really is no difference.
cmiyc
With current limiting resistors, right?  Otherwise, you'll be buying new Leonards soon.
