Topic: Yet another crash (Read 1 time) previous topic - next topic
sbright33
3 in one day?  Completely unrelated.  The clock keeps getting slower and slower until it stops.  I can tell because my code uses delay() to make beeps.  Some of the values in () are hard coded constants.  Still they slow down from 1khz to 1hz clicks.  This one is repeatable.  I would post my code but it would take you much time to find the problem.  I have 2 arrays but I'm very careful about going out of bounds.  No pointers.  Not using 2k.  How else can I effect the clock?  Instead of solving this specific problem, I'd like to learn in general what are the possible causes of this.  The slow down occurs over a minutes time.  After I have sped up my program 100x to test for something like this by changing the innermost delay.  It happens about 10 minutes in, which would be 1000 min in normal speed.  After we have discussed in general how this could happen, I will post my code if anyone wants to read it.  Thank you for listening!
Jantje
The only reason I can think of is interrupts. Do you use them?
Best regards
Jantje
PS
If you fall... I'll be there for you!
-Floor
great footer  :)
Do not PM me a question unless you are prepared to pay for consultancy.
Jack Christensen
Of course "post your code" is the usual mantra but there is a point here when there are hundreds or thousands of lines of code, multiple modules, etc. Might be a bit much to expect people to wade through.
What I usually do in such a situation is start paring down the code to the bare minimums, find the smallest (or reasonably small) program that still exhibits the symptom.
Sometimes the problem is discovered along the way, and if not, I have a much more concise program that I can post!
sbright33
Interesting, the same code doesn't do this, on different hardware.  Uno vs Pro.
Jantje
It's not clear to me whether your  problem exists on the pro or the uno.
if you only have it on the pro you may run out of memory space. Do you have memory leakage?
do you run the pro on 3.3 or 5 volts?
Best regards
Jantje
