Loading...
Pages: [1]   Go Down
Author Topic: COM 6 not found  (Read 567 times)
Bristol, UK
Offline Offline
Jr. Member
part time tinkerer
View Profile
hi,
i get an irritating issue with my arduino uno, connected via usb.
whenever i run a sketch that uses the serial monitor to view the outcome, i can program the arduino once, but then i get COM6 not found error the next time i try.
changing usb ports doesn't free it up, and the only way i can find to solve it it to reboot the machine.
the full error
Code:
processing.app.SerialNotFoundException: Serial port 'COM6' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.<init>(Serial.java:191)
at processing.app.Serial.<init>(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:172)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1706)
at processing.app.Sketch.exportApplet(Sketch.java:1662)
at processing.app.Sketch.exportApplet(Sketch.java:1634)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2346)
at java.lang.Thread.run(Thread.java:619)
Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Can you test this and say me if problem continues? http://arduino.cc/forum/index.php/topic,118440.0.html
I have replaced the winavr version, I was suspecting that was the error with serial ports
Logged
My homepage/blog: http://erwin.ried.cl
Offline Offline
Newbie
View Profile
I have same issue. ERW 1.0.3 does not solve the problem still get error after 1 upload. Does anyone know how to fix this.
ERW 1.0.3 does not even give the auto fix option that says it's supposed to have.  smiley-confuse
Logged
Offline Offline
Newbie
View Profile
/bump
no one on the internet has solved this or figured why it happens to some people
Logged
Offline Offline
Jr. Member
View Profile
Change the COM port in device manager via system via control panel
Logged
Offline Offline
Newbie
View Profile
Tried, does not work.  smiley-sad
Logged
Offline Offline
Newbie
View Profile
/bump
(for 3 weeks no replies no solution posted)
Logged
Pages: [1]   Go Up
Print
Jump to:
