Topic: webserver for 5 relays (Read 8501 times) previous topic - next topic
simisv
HI
I am using the arduino uno and enc28j60 . tested and is ok . i want to control 5 relays but am stuck .
i used this example .
Thank you
GaryP
What is the problem? Little more specific would help.
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
simisv
Hi GaryP
Thank you for response
I do not know how to modify the program to work with 5 relays . I tried unsuccessfully .
GaryP
Ok, show the code you tried, but didn't work. Maybe there's something we can fix?
You must have tried something, and it failed, right?
Cheers,
Kari
simisv
this is the program . When i tried to connect the result is : web page not available
GaryP
How did you connect it, how did you test it? Please add your code using #-button, should look like this:
Code: [Select]
//your code
By the way, I'm not sure if I can help, I use 0023 IDE. Sorry about that...
Cheers,
Kari
GaryP
I tried to look at your code, but all the HTML-stuff inside...
You should try to minimize that part, I don't think all that is needed at this point.
Cheers,
Kari
winkleink
I was doing something similar but controlling from a PC based webserver.
The Arduino is running a web server sketch as well and reading the HTTP Request details for the actions.
With this you can control 5 relays
Below is the link to the details:
http://winkleink.blogspot.co.uk/2012/08/arduino-ethernet-ethercard-xamp-web.html
Look at the Arduino Code to see how it's done.
I have since modified the PC server PHP code so it can control any number of Arduinos and Pins by storing the details in a mySQL database.
Hopefully, this helps.
Winkleink.
seanz2003
#8
Sep 20, 2012, 11:03 am Last Edit: Sep 20, 2012, 11:19 am by seanz2003 Reason: 1
I made a similar sketch a few months ago and took forever to figure out how the example really worked so Included a few notes on this incomplete sketch that may make it a little more understandable.
Code: [Select]
#include "etherShield.h"
#include "ETHER_28J60.h"
const int fanPin = 6;
const int ledPin = 7;
//                         Relay pins go here
const int ethernet_cs = 10;
static uint8_t mac[6] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24};  //   Something unique to your network
static uint8_t ip[4] = {192, 168, 1, 15};                           //        unique to your network
static uint16_t port = 80;
ETHER_28J60 e;
 e.setup(mac, ip, port);
 pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  // relay pins here
processClient();
void processClient(){
char* params;
 if (params = e.serviceRequest())
   e.print("<h1><a href='/?relay1=off'>Arduino Web Remote</a></h1>");                     // **take note of: <a href='/?relay1=off'> that is the important bit that the arduino looks at and decides what do **
   e.print("<button type='button' onclick=location.href='?relay1=off'>RELAY1</button>");              // a button for relay1, notice: href='?relay1=off'
   e.print("<button type='button' onclick=location.href='?fan=off'>FAN</button>");                 // copy for more buttons to control more relays...
   if (strcmp(params, "?relay1=on") == 0)             // this statement looks at what comes directly after this bit from above:  <a href='/... then you setup else if's to control pins
    digitalWrite(relay1, HIGH);              // set your relay high
     e.print("<a href='?relay1=off'><button style='border: 1px solid #ff0000; border-left: 10px solid #ff0000' type='button'>relay1 IS ON</button></a>");
       e.print("<br>");
   else if (strcmp(params, "?relay1=off") == 0)
     digitalWrite(relay1, LOW);
     e.print("<a href='?relay1=on'><button style='border: 1px solid #000; border-left: 10px solid #000' type='button'>relay1 IS OFF</button></a>");
   else if (strcmp(params, "?fan=on") == 0)
     digitalWrite(fanPin, HIGH);
     e.print("<a href='?fan=off'><button style='border: 1px solid #ff0000; border-left: 10px solid #ff0000' type='button'>FAN IS ON</button></a>");
   else if (strcmp(params, "?fan=off") == 0)
     digitalWrite(fanPin, LOW);
     e.print("<a href='?fan=on'><button style='border: 1px solid #000; border-left: 10px solid #000' type='button'>FAN IS OFF</button></a>");
   /* copy and paste else if's (2 for each relay- one to turn it on, the other alse if turns it off) so for 5 relays that should be one if statement followed
   by 9 else if's */
   e.respond();
simisv
Thank you all  !!!
I solved . The problem is low memory on mega328 . I can't use button's , only links . Is working fine now , but i need to save status of the relays on internal eeprom  and not working so far .
I tested the examples from arduino and serial monitor show that eeprom program is working fine ,but i can't connect data from eeprom to relay status .
simisv
#10
Sep 29, 2012, 02:24 pm Last Edit: Sep 29, 2012, 02:28 pm by simisv Reason: 1
Thank you all  !!!
Code: [Select]
// A simple web server to turn 5 LED on or off
#include <EEPROM.h>
int outPin0 = 0; // relay1 to pin 4
int outPin1 = 1; // relay2 to pin 3
int outPin2 = 2; // relay3 to pin 2
int outPin3 = 3; // relay4 to pin 1
int outPin4 = 4; // relay5 to pin 0
const int ledPin =  9; // led status pin 9
byte value0;
byte value1;
byte value2;
byte value3;
byte value4;
int ledState = LOW;
long previousMillis = 0;
long interval = 1000;
  0x54, 0x55, 0x58, 0x10, 0x00, 0x24};   // this just needs to be unique for your network,
  192, 168, 0, 2}; // IP address for the webserver
static uint16_t port = 80; // Use port 80 - the standard for HTTP
ETHER_28J60 e;
  pinMode(outPin0, OUTPUT);
  pinMode(outPin1, OUTPUT);
  pinMode(outPin2, OUTPUT);
  pinMode(outPin3, OUTPUT);
  pinMode(outPin4, OUTPUT);
  pinMode(ledPin, OUTPUT);
  value0 = EEPROM.read(0x00);
  value1 = EEPROM.read(0x01);
  value2 = EEPROM.read(0x02);
  value3 = EEPROM.read(0x03);
  value4 = EEPROM.read(0x04);
  if (byte value0=0)
    digitalWrite(outPin0, LOW);
  else if (byte value0=1)
    digitalWrite(outPin0, HIGH);
  if (byte value1=0)
    digitalWrite(outPin1, LOW);
  else if (byte value1=1)
    digitalWrite(outPin1, HIGH);
  if (byte value2=0)
    digitalWrite(outPin2, LOW);
  else if (byte value2=1)
    digitalWrite(outPin2, HIGH);
  if (byte value3=0)
    digitalWrite(outPin3, LOW);
  else if (byte value3=1)
    digitalWrite(outPin3, HIGH);
  if (byte value4=0)
    digitalWrite(outPin4, LOW);
  else if (byte value4=1)
    digitalWrite(outPin4, HIGH);
  char* params;
    e.print("<h1>Simielk WRemote<h1>");
    e.print("<h2><a href='/?d1=of'>out1off</a></h2>");
    e.print("<h2><a href='/?d1=on'>out1on</a></h2>");
    e.print("<h2><a href='/?d2=of'>out2off</a></h2>");
    e.print("<h2><a href='/?d2=on'>out2on</a></h2>");
    e.print("<h2><a href='/?d3=of'>out3off</a></h2>");
    e.print("<h2><a href='/?d3=on'>out3on</a></h2>");
    e.print("<h2><a href='/?d4=of'>out4off</a></h2>");
    e.print("<h2><a href='/?d4=on'>out4on</a></h2>");
    e.print("<h2><a href='/?d5=of'>out5off</a></h2>");
    e.print("<h2><a href='/?d5=on'>out5on</a></h2>");
    if (strcmp(params, "?d1=on") == 0)
      byte value0=1;
      e.print("<h1><a href='?d1=of'></a>1 is ON</h1>");
    else if (strcmp(params, "?d1=of") == 0)
      byte value0=0;
      e.print("<h1><a href='?d1=on'></a>1 is OFF</h1>");
       if (strcmp(params, "?d2=on") == 0)
      byte value1=1;
      e.print("<h1><a href='?d2=of'></a>2 is ON</h1>");
    else if (strcmp(params, "?d2=of") == 0)
      byte value1=0;
      e.print("<h1><a href='?d2=on'></a>2 is OFF</h1>");
        if (strcmp(params, "?d3=on") == 0)
      byte value2=1;
      e.print("<h1><a href='?d3=of'></a>3 is ON</h1>");
    else if (strcmp(params, "?d3=of") == 0)
      byte value2=0;
      e.print("<h1><a href='?d3=on'></a>3 is OFF</h1>");
        if (strcmp(params, "?d4=on") == 0)
      byte value3=1;
      e.print("<h1><a href='?d4=of'></a>4 is ON</h1>");
    else if (strcmp(params, "?d4=of") == 0)
      byte value3=0;
      e.print("<h1><a href='?d4=on'></a>4 is OFF</h1>");
        if (strcmp(params, "?d5=on") == 0)
      byte value4=1;
      e.print("<h1><a href='?d5=of'></a>5 is ON</h1>");
    else if (strcmp(params, "?d5=of") == 0)
      byte value4=0;
      e.print("<h1><a href='?d5=on'></a>5 is OFF</h1>");
        e.respond();
        EEPROM.write(0x00, value0);
   EEPROM.write(0x01, value1);
   EEPROM.write(0x02, value2);
   EEPROM.write(0x03, value3);
   EEPROM.write(0x04, value4);
    // blink the LED.
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);}
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
