Topic: Arduino UNO R3 Help Please (Read 2175 times) previous topic - next topic
joshreynolds1982
This is what happened. I received my Arduino Uno R3 in the mail. I followed the instructions perfectly and successfully loaded the blink sketch. I then installed the Parallax PIR Sensor and downloaded a sketch for it and it worked great! I got tired of it after a while and reconnected to my Windows 7 X64 as usual, and it just kept playing the connection noise over and over again. You know the one that you hear when you plug anything into a USB port. They are USB 2.0's if you're wondering. In the device manager the Com Ports have disappeared. I have system restored, cleaned my registry and junk files. Re-downloaded the IDE 1.0.1 and the older 1.0. Nothing works at all. I am very frustrated and can't seem to find anyone that has had the same problem. Also I have changed USB connector cords and I have tried another PC with the same Windows 7 X64. I could not update the drivers on the other PC it said they were up to date. I uninstalled and re-installed but no luck. Can anyone help please?
cmiyc
With nothing connected to the Arduino board, it does not appear as a COM port anymore?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
joshreynolds1982
Thanks for the reply. I have tried connecting the arduino without and with things connected to it. No com port is found.
cmiyc
Does the power LED turn on and then fade out?
joshreynolds1982
Lights that turn on and stay on are the ON light (green) and the Pin 13 light (amber).
cmiyc
So if the com ports are not in device manager, how are you able to check the driver version?
joshreynolds1982
Here is what the arduino looks like when it is plugged up to my USB port.
joshreynolds1982
On my computer the com 3 port was there when everything was running smoothly. When it wouldn't connect the com 3 port disappeared. On the other computer I started the normal setup. I saw the device in the device manager but when I tried to update it it said the drivers were up to date and it stayed with a yellow triangle.
eried
You need to install the correct inf file. I worked on an automatic driver installer but I am not sure if it fixes current non working devices (I am using an official toolkit from microsoft to install drivers). http://arduino.cc/forum/index.php/topic,118440.msg891474.html <- select the board you own when asked.
If you test it and works for you please post it here so I can know it fixes those kind of problem. If no, maybe I can work to troubleshoot this kind of issues in an automated way :)
My website: http://ried.cl
joshreynolds1982
Thank you. I'm downloading it now. I will post after it fixes it or not.
joshreynolds1982
I installed the program and the drivers for the UNO R3. However, when I plug the arduino into my pc it still constantly replays the connected tone over and over again and does nothing. I can't find anything in the device manager either.
joshreynolds1982
Here is the error. It doesn't really help seeing how my pc doesn't recognize the arduino. But I thought you would like to see it anyways.
eried
Not really, it is something I screwed in the last version with new WinAVR, I will try to fix that soon, but can you point the Device manager to install "C:\Program Files (x86)\Arduino\Arduino ERW 1.0.1b\drivers\Arduino UNO REV3.inf" this driver? or the one from your other arduino ide folder?
joshreynolds1982
In the device manager there is not anything there resembling arduino uno or an object that has a yellow triangle like usual. So there is nothing I can point to it. When the usb connecting tone sounds over and over the device manager flickers but does not give me anything that I can point to those drivers.
eried
I see, so the most probable thing is the 8u2 is dead or not properly configured. Search for instructions to set it in DFU mode to see if is alive :D
