Topic: What is the most expensive board you ever smoked? (Read 7301 times) previous topic - next topic
retrolefty
@ Grumpy Mike  " Only blew two parts but one was a BGA device. "
then you find out how good you are with a solder sucker and wick ?
As the solder points are underneath on a BGA packaged device, a solder sucker and wick would not be of any use.
Lefty
Boffin1
"a solder sucker and wick would not be of any use."
Just my attempt at humour :-)
45 years of editing projects with a knife and soldering iron, then I found Arduino !
Osgeld
hot air and a good tap against the desk would fix that (hehe)
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
rfbase
EPROM and system board in an old Telxon data collection terminal. We connected it to a DEC mini/mainframe (1989-ish) with RS232. One of the pins was high voltage from the DEC and smoked the entire Telxon unit. Left a black mark on the DEC case where the unit was sitting. When we were connecting it I was joking around saying "if you guys have a fire extinguisher around you might want it close by".....
Last time I used that joke.
kf2qd
I didn't do this, but I worked for a while building CNC plasma cutting machines. The plasma power supplies came in and we were supposed to check the voltage settings. One of the supervisors was setting a new set of plasma supplies up and hooked a supply that was wired for 220 to 440. It didn't last very long...
cjdelphi
I once flashed an $1,500 motherboard back in 2000.. although not smoked, not turning on either lol
Boffin1
Back in the BA  ( before Arduino ) days,  I made a prototype washing machine timer with about 6 CMOS chips, to replace the clockwork one that was packing up in a popular machine.
My partnet waited for me to finish, as he had to drive 1000 Km to the factory for them to test it.
After I had it working I sealed it in white silicone so they couldnt copy it.
I didnt let it set enough I think, and when I did a final test, the silicone lit up with a brief white flash.
I built up another, and my partner drove through the night to get it there.
They approved it and we were busy with the megabucks agreement over 3 years, when they went bust :-(
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
