Author Topic: ATtiny85 : Are these all different?  (Read 322 times)
On the ATtiny85 webpage
http://www.atmel.com/devices/attiny85.aspx
is the list of different ATtiny under "Ordering Codes".
[ATTINY85-20MU, ATTINY85-20MUR, ATTINY85-20PU,...........]
The difference between them is listed under 'speed' and 'package' columns of that table.  What is that speed  or package means. And how do we decide  which one fits  the need.
Or if you can point me to where this is explained.
South England
Package just means the "shape" of the component, e.g. whether it's designed to be mounted through-hole (as you would on a breadboard for example) or surface-mounted.
Speed is exactly that - how fast the clock oscillator can run (which affects how quickly the '85 can execute instructions and perform other tasks).
For example, I have the ATtiny85-20PU. They are 8-pin DIP and will run up to 20MHz, although in my setup I usually have them running at 8Mhz as it's more than enough for my applications. If in doubt, those are probably the ones you want for prototyping with!
« Last Edit: September 02, 2012, 01:39:25 pm by BulletMagnet83 » Logged
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
Then there are the "V" parts, which run at lower voltages, although also at slower clock speeds, e.g. ATtiny85V-10PU.
The datasheet explains all...
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
