Loading...
Pages: [1]   Go Down
Author Topic: K type thermocouple  (Read 2223 times)
Offline Offline
Newbie
View Profile
Can anyone tell me if I can hook-p a type k thermocouple to an arduino uno?
Logged
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
Not without external circuitry to handle getting cold reference junction information. The best way to utilize thermocouples is to use the purpose designed ICs made for them.
Lefty
Logged
Grand Blanc, MI, USA
Offline Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
http://www.adafruit.com/products/269
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Thermocouple output voltages are tiny (microvolts per degree) - far too small to use directly with Arduino analog inputs.  Themocouple ICs handle both the compensation for the cold-junction temperature and the precision amplification needed to produce usable voltage levels - some include an ADC as well so only need digital interfacing.
Logged
Santa Fe
Offline Offline
Full Member
View Profile
Go with what Jack pointed out. Its self contained and uses a digital readout. Google MAX31855... there are lots more at possibly better prices... if you don't mind waiting for a slow boat from China.
There are several  scripts ready to go. Just remember that the digital inputs from the Arduino have to be 3.3 volts, not 5 volts.
Logged
0
Offline Offline
Faraday Member
View Profile
Quote
Google MAX31855
The older MAX6674 and MAX6675 both work with K types, they work at 5V, and there is working arduino libraries (at least, there's a library for one that can be modified for the other).
I think someone even has a shield available.
-j
Logged
Santa Fe
Offline Offline
Full Member
View Profile
Quote
I have not seen one ,  but you can buy adapters to 8 Pin SOIC to DIP8 Adapters. They are a pain to solder, but they do work.
http://www.futurlec.com/SMD_Adapters.shtml
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
AD595 in DIP as used here
https://www.sparkfun.com/products/81
www.arrowelectronics.com
http://components.arrow.com/part/detail/52071S5444913N2771
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
ok now my simple question is, what if i just want to read to the nearest 100c... do i need an amp?
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Take a look at the AD595 datasheet, see what level of input it is expecting from the thermocouple.
The '328P can take in 1.1V/1024 as the lowest reading, about 1mV. Probably not reliably, will need a couple of mV for a reliable reading.
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Looks like type K's are around 4mV per 100C. It should work.
http://srdata.nist.gov/its90/download/type_k.tab
Logged
Pages: [1]   Go Up
Print
Jump to:
© 2011 Arduino Forum: Powered by SMF 1.1.18 | SMF © 2013, Simple Machines
