Topic: Arduino WiFi Shield UDP Support (Read 31230 times) previous topic - next topic
srrichie
By the way, sorry for the late info but I've realized I'm using a shield with the HDG204 chip
srrichie
So, after 30 hours of craziness, debug, trial and error, I went directly to show the board to one of the guys of Officine Arduino here in Italy.
And it looks like the shield is defective.
OMG.
Thanks you all for the support
ohhopi
Hey Tim !
Indeed while copying the code I added a "z" in it but it "works" here it is with the same bug i was talking about earlier :
Code: [Select]
#include <SPI.h>
#include <WiFI.h>
#include <WiFiUdp.h>
#include <Time.h>
int status = WL_IDLE_STATUS;
char ssid[] = "SSID"; // your network SSID (name) Your network name here, case sensitive!
char pass[] = "pass";  // if your network doesn't use WPA or WEP, change the line below that says "status = WiFi.begin(ssid, pass);"
/* ******** NTP Server Settings ******** */
/* us.pool.ntp.org NTP server
   (Set to your time server of choice) */
IPAddress timeServer(64, 90, 182, 55);
/* Set this to the offset (in seconds) to your local time
   This example is GMT + 2 */
const long timeZoneOffset = 7200L;
/* Syncs to NTP server every 15 seconds for testing,
   set to 1 hour or more to be reasonable */
unsigned int ntpSyncTime = 15;
/* ALTER THESE VARIABLES AT YOUR OWN RISK */
// local port to listen for UDP packets
unsigned int localPort = 8888;
// NTP time stamp is in the first 48 bytes of the message
const int NTP_PACKET_SIZE= 48;
// Buffer to hold incoming and outgoing packets
byte packetBuffer[NTP_PACKET_SIZE];
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
// Keeps track of how long ago we updated the NTP server
unsigned long ntpLastUpdate = 0;
// Check last time clock displayed (Not in Production)
time_t prevDisplay = 0;
     // make a little light show on the WifiShield
  pinMode(9, OUTPUT);
  for(int i = 0; i < 50; i++){
    digitalWrite(9, HIGH);
    delay(i);
    digitalWrite(9, LOW);
    delay(i);
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  Serial.println("Wifi Shield present");
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    // wait 10 seconds for connection:
    delay(10000);
  Serial.println("Connected to wifi");
  printWifiStatus();
  Serial.println("\nStarting connection to server...");
   //Try to get the date and time
   int trys=0;
   while(!getTimeAndDate() && trys<10) {
     trys++;
// Do not alter this function, it is used by the system
int getTimeAndDate() {
   int flag=0;
   Udp.begin(localPort);
   sendNTPpacket(timeServer);
   if (Udp.parsePacket()){
     Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
     unsigned long highWord, lowWord, epoch;
     highWord = word(packetBuffer[40], packetBuffer[41]);
     lowWord = word(packetBuffer[42], packetBuffer[43]);
     epoch = highWord << 16 | lowWord;
     epoch = epoch - 2208988800 + timeZoneOffset;
     flag=1;
     setTime(epoch);
     ntpLastUpdate = now();
   return flag;
unsigned long sendNTPpacket(IPAddress& address)
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  packetBuffer[0] = 0b11100011;
  packetBuffer[1] = 0;
  packetBuffer[2] = 6;
  packetBuffer[3] = 0xEC;
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  Udp.beginPacket(address, 123);
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
// Clock display of the time and date (Basic)
void clockDisplay(){
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
// Utility function for clock display: prints preceding colon and leading 0
void printDigits(int digits){
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
// This is where all the magic happens...
    // Update the time via NTP server as often as the time you set at the top
    if(now()-ntpLastUpdate > ntpSyncTime) {
      int trys=0;
      while(!getTimeAndDate() && trys<10){
        trys++;
      if(trys<10){
        Serial.println("ntp server update success");
      else{
        Serial.println("ntp server update failed");
    // Display the time if it has changed by more than a second.
    if( now() != prevDisplay){
      prevDisplay = now();
      clockDisplay();
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
timKnapen
Hi Ohhopi,
So I understand you still get the same feed back from Serial: "ntp server update failed"
What did you try to find where the bug is? Did you try my suggestion to start from a tested working example and seeing when it starts failing? Another good thing to do is add a lot of debug printouts. So everytime you think your code does something the Serial prints this out for you so you are sure it is actually the way you expect it to be.
One thing I see that is probably not right is this:
in getTimeAndDate() :
Code: [Select]
Which means you are doing this request every second. According to this pagehttp://tf.nist.gov/tf-cgi/servers.cgi you shouldn't query the servers more than once every 4 seconds. You'll see in the UDPNTPClient example that they wait 10 seconds between each call.
ale16289
I understand what do you say before...but if i want to the udp connection with the shield wifi(R3) plus an arduino Due what i have to do, because i follow the same passage but something goes wrong. This is the message
In file included from c:\users\alepao\desktop\arduino-1.5.2\hardware\tools\g++_arm_none_eabi\bin\../lib/gcc/arm-none-eabi/4.4.1/../../../../arm-none-eabi/include/stdio.h:46,
                 from C:\Users\alepao\Documents\Arduino\libraries\WiFi\/utility/debug.h:13,
                 from C:\Users\alepao\Documents\Arduino\libraries\WiFi\WiFiClient.cpp:6:
c:\users\alepao\desktop\arduino-1.5.2\hardware\tools\g++_arm_none_eabi\bin\../lib/gcc/arm-none-eabi/4.4.1/../../../../arm-none-eabi/include/sys/types.h:93: error: conflicting declaration 'typedef short unsigned int u_short'
C:\Users\alepao\Documents\Arduino\libraries\WiFi\utility/socket.h:71: error: 'u_short' has a previous declaration as 'typedef uint16 u_short'
C:\Users\alepao\Documents\Arduino\libraries\WiFi\WiFiClient.cpp: In member function 'virtual int WiFiClient::read(uint8_t*, size_t)':
C:\Users\alepao\Documents\Arduino\libraries\WiFi\WiFiClient.cpp:107: error: no matching function for call to 'ServerDrv::getDataBuf(uint8_t&, uint8_t*&, size_t*)'
C:\Users\alepao\Documents\Arduino\libraries\WiFi\utility/server_drv.h:26: note: candidates are: static bool ServerDrv::getDataBuf(uint8_t, uint8_t*, uint16_t*)
dariosalvi
#50
May 31, 2013, 03:08 pm Last Edit: May 31, 2013, 05:37 pm by dariosalvi Reason: 1
I have manage to make the UDP work properly on the WIFI shield without too much hassle.
The new version of the Arduino environment (1.0.5) already includes the WIFI shield libraries, and among its examples it has one that uses UDP: go to Examples -> WIFI -> WifiUdpNtpClient
First try:
I have just uploaded the sketch to the Arduino (after setting the proper WIFI SSID and password) but it did not work. In fact, watching at the messages on the serial port I saw:
Code: [Select]
Attempting to connect to SSID: XXXX
Connected to wifi
SSID: LST-D204
IP Address: 192.168.1.132
signal strength (RSSI):-53 dBm
0
0
0
0
0
At some point, where in the Arduino sketch says Serial.println( Udp.parsePacket() ); it was printing me out this 0, meaning that probably the library was not supported by the firmware.
Firmware update:
Be careful about the firmware. It seems that there are two git repositories with the shield's code
this:  https://github.com/arduino/wifishield
and this: https://github.com/arduino/Arduino/tree/master/hardware/arduino/firmwares/wifishield/binary
I have used the second one, which was more recent and I think is also the one that is more official, so remember, WIFI shield's firmware is here:
https://github.com/arduino/Arduino/tree/master/hardware/arduino/firmwares/wifishield/binary !!!!!
You have to donwload the files wifi_dnld.elf and wifiHD.elf.
Then I have followed the instructions given here:
http://arduino.cc/en/Hacking/WiFiShieldFirmwareUpgrading
they are not very good, but all the steps are described at least.
As I work on Windows I had to download the Atmel's tools here http://www.atmel.com/tools/FLIP.aspx
Then I removed the shield from the Arduino, put the jumper in programming mode and connected the mini USB port to the computer.
If the driver for the AT32UC3 is not found you have it available in your computer inside the Flip folder, in my case here: C:\Program Files (x86)\Atmel\Flip 3.4.7\usb
The I have updated BOTH the HDG104 and the AT32UC3 firmwares.
For updating the HDG104 firmware type:
Code: [Select]
C:\Program Files (x86)\Atmel\Flip 3.4.7\bin>batchisp.exe -device AT32UC3A1256 -hardware usb -operation erase f memory flash blankcheck loadbuffer D:\D
ownloads\Development\Arduino\wifi_dnld.elf program verify start reset 0
(will have to change the path to the wifi_dnld.elf file that you have downloaded from the GIT repository)
you will see:
Code: [Select]
Running batchisp 1.2.5 on Fri May 31 14:17:14 2013
AT32UC3A1256 - USB - USB/DFU
Device selection....................... PASS
Hardware selection..................... PASS
Opening port........................... PASS
Reading Bootloader version............. PASS    1.0.2
Erasing................................ PASS
Selecting FLASH........................ PASS
Blank checking......................... PASS    0x00000 0x3ffff
Parsing ELF file....................... PASS    D:\Downloads\Development\Arduino\wifi_dnld.elf
WARNING: The user program and the bootloader overlap!
Programming memory..................... PASS    0x00000 0x2902b
Verifying memory....................... PASS    0x00000 0x2902b
Starting Application................... PASS    RESET   0
Summary:  Total 11   Passed 11   Failed 0
Then for updating AT32UC3 firmware you have to type:
Code: [Select]
ownloads\Development\Arduino\wifiHD.elf program verify start reset 0
In my case, after the previous update, the board got stuck so I got:
Code: [Select]
Running batchisp 1.2.5 on Fri May 31 14:18:09 2013
Opening port........................... AtLibUsbDfu: 3EB 2FF8 no device present.
FAIL    Could not open USB device.
ISP done.
So I just removed the USB cable and put it back again, so once again:
Code: [Select]
and you'll see:
Code: [Select]
Running batchisp 1.2.5 on Fri May 31 14:26:28 2013
Parsing ELF file....................... PASS    D:\Downloads\Development\Arduino\wifiHD.elf
Programming memory..................... PASS    0x00000 0x3fe2b
Verifying memory....................... PASS    0x00000 0x3fe2b
Good! now connect the Wifi Shield to the Arduino again and run the WifiUdpNtpClient example.
If everything works you should see on your serial port:
Code: [Select]
Connected to wifi
SSID: LST-D204
48
packet received
Seconds since Jan 1 1900 = 3578992778
Unix time = 1370003978
The UTC time is 12:39:38
which means that everything is working ;)
BodaAllMighty
Hi everyone
I'm trying to use WiFiUdp.h with  Arduino DUE R3 and WiFi Shield R3.
For reason I'm not able to load e  WiFi Udp NTP Client.
Is there any support for Arduino DUE for WiFiUdp.h?
I'm missing something?
Any help will be greatly appreciated.
Thanks
hacaro
Many thanks Tim !
Now UDP Communication works fine :-)
Max
kavih
Many thanks dariosalvi! Your tutorial helped me get my brand new wifi shield working with UDP and TCP connections. Cheers!  :)
StanleyAudio
Many thanks dariosalvi, I followed your procedure and got the exact screen printout as yours in upgrading the shield. However when I put the shield back and tried the WiFiUdpNtpClient, I didn't get the same result, looks like that I can't connect to the server. What I discovered is that the router returned an IP address of 0.0.0.0, then I used the scanNetworks sketch to check on the router I used. What I found is that this sketch showed my shield's MAC address is 0:0:0:0:0:0 ! As I remembered my shield MAC address was some number other than all zeros! Does that mean I eraseed the MAC address also during the upgrade? Anyone has the same problem? Help please!
aimh_2327
#55
Oct 15, 2013, 11:52 pm Last Edit: Oct 16, 2013, 09:56 pm by aimh_2327 Reason: 1
Hi everyone!!!
I have a bit problem with example WiFiUdpSendRecieveSting
First time I debug, it works very well. (I send 3 string "acb")
Code: [Select]
Port open
Attempting to connect to SSID: Connectify-Minh
Connected to wifi
IP Address: 192.168.12.101
signal strength (RSSI):-49 dBm
Received packet of size 3
From 192.168.12.1, port 2390
Contents:
acb
Contents:
acb
Contents:
acb
Second time I debug, it just recieved once and didn't send "acknowledged".... (I send 3 string "acb")
Code: [Select]
Port open
Connected to wifi
From 0.0.0.0, port 0
Contents:
123
Third time, it doesn't  run anymore.
Code: [Select]
Port open
Plz show me my misstake!!! Thank for your help :D
