Topic: AVRISP MKII AVRDUDE Can't find USB (Read 21549 times) previous topic - next topic
wolverineairsoft
My layout is good, no crossed wires. I have a second populated board that I have not programmed yet. I'll power it up and make sure that pin isn't high before programming. I'll also check all the other pins and see what's going on.
Again, just to verify: Since I'm compiling in IDE it doesn't matter that I'm using libraries in my code formulated for IDE/arduino. Once it's in .hex, it's all the same...
I know maybe these are silly questions, but I'm a mechE, so I'm struggling to understand what the issues are here.
Thanks for the help! my inlaws have an XP computer. I may see if IDE agrees any better with the MKII on that.
Thanks!
wolverineairsoft
UPDATE:
Progress! I finally got access to an xp computer. got ide installed and the libusb0.dll driver for the MKII. It did exactly the same thing as with AVR studio. I wrote a simple blink code and wha-do-ya-know...it worked!
At this point I have determined that there is a problem somehow with the lcd screen. I checked that all my pin assignments are correct. It will initialize with no problem and give me a cursor. I can even move that cursor anywhere I want. I can turn the back light on and off. However when I try to print to it, it does essentially nothing. If I tell it to print any single character (that I've tried) it prints a bunch of spaces followed by "45" followed by more spaces. It's late, I have to go to bed. but if anyone has ideas as to what the problem might be, please let me know, thanks! Goodnight world.
wolverineairsoft
Interesting. It prints numbers correctly if I give it the correct base input. So somehow it's just not handling the strings I'm trying to feed it properly...hmmmm.....
PaulS
Quote
Specifying the correct base is usually a prerequisite for proper behavior.
Quote
What isn't? What strings?
Quote
Which LCD is that? How is it connected?
wolverineairsoft
newhaven COG character display. 2x16. I am using the doglcd libraries. print command is supposed to accept a variety of character inputs. strings, char*, etc. without sepecification. I am simply feeding it this:
lcd.print("hello world!");
and it is not dealing with it properly.
I do not know what you mean by "how is it connected". would you like a diagram? It is mounted on a custom pcb which essentially acts like a 3.3v arduino mini with atmega168. it uses pins: (8, 7, 5, 6, A3, A4) as I recall. initializes properly with those pins. If you are wondering if it's a connection issue, it is rather unlikely. possible that I crossed a wire on the board, but the population is professionally done by a lady that does custom boards for the military. Most likely the problem lies elsewhere. I can post schematic and brd layout if anyone is interested in looking at them.
Thanks!
wolverineairsoft
Since question has become more one of dispay issues, I have started a new topic here:
http://arduino.cc/forum/index.php/topic,125470.0.html
