Topic: Teensy 3.0 (Read 74396 times) previous topic - next topic
Nantonos
- is there a forum for the Teensy 3.0 or is this thread the best place to ask questions?
This is a good place to ask questions and there is also now a Teensy forum.
- I notice in the Beta5 IDE Tools menu that you can choose one of three CPU speeds - e.g. to overclock at 96MHz. Is this selection all you need to do or do you also have to make some sort of hardware change?
I believe that is all you need. Beta7 IDE was just released btw.
el_supremo
Quote from: Coding Badly
Using float or double?
float.
@Nantonos. Thanks for the info. I've now found the forum and also discovered just how trivial it is to run a sketch overclocked at 96MHz.
I suspect that sorting out the DSP stuff is gonna be a bit less than trivial though :-)
Pete
Don't send me technical questions via Private Message.
Nantonos
Yes, hence my lack of reply on that point.
