Loading...
Pages: 1 [2]   Go Down
Author Topic: Super Bright Red Led - BC547B Transistor, but which Resistors?  (Read 1161 times)
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
:-p
Too bad I don't have those. But I will see if the local shop carries it... (doubt it)
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
You can use ULN2803 as buffer on 74HC595.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Sounds interesting, but how can I do that? Do you mind teaching me, pretty please? ;-) ;-)
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Can't I just use 2 x ULN2803 chips and 8 pins on the Arduino? (I don't need many free pins, only 4 for a multiplexer, and 2 for UART)
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
I thought you wanted 16 non-multiplexed LEDs?
Connect up the 74HC595 & ULN2803 like I show at the bottom of this schematic.
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
It doesn't matter, I can do both, just wondering on what I could do with the stuff I already have that will get my ultra brightness.  smiley-mr-green
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Non-multiplexed for ultra brightness smiley-cool
I'll be in the next room smiley-wink
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Maybe I'm not explaining things right or I just got lost.  smiley-red smiley-eek-blue
Anyway, as I asked, can't I just use 2 x ULN2803 chips and 8 pins from the Arduino?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Yes you can.
Post a schematic when you're ready.
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Ok, here's the final deal, a friend also helped me out with the math.  smiley-mr-green
I will drive 2 x 74HC595 in series, so I can get 16 outputs.
Them I will drive those 16 outputs directly to 2 x ULN2803A
On each output of the ULN2803A, I will put a 100 ohm resistor + UB LED. (2.3Vf 20ma)
In my tests it works perfectly. And if I want a second LED to make it more bright, I just put another 100 ohm resistor and add in parallel.
Now I need to get some White-Frost Plexy to test how this will look like.
Here's something some guys did that are similar to my idea. But I plan on using RED-Only LEDs (Ultra Bright) and a 4 x 4 pattern instead.
http://e2e.ti.com/group/microcontrollerprojects/m/msp430microcontrollerprojects/447779.aspx
The difference is that in my project, each square will be touch-sensitive. ;-)
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
That'll work.
2 LED/resistors in parallel per outpin will work fine too.
(5V - 2.3V - 0.7V)/100 = 20mA (0.7V is Vce across the ULN2803, rises to 0.9V typical at 100mA)
How are you making them touch sensitive?
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
I'm using the CapSense Library and a 16ch Analog Multiplexer. I had to mess with the code around a bit, in order to get only true positive touches.
http://arduino.cc/forum/index.php/topic,121508.0.html
As soon as I have the first prototype ready, I will post about it.  smiley-mr-green
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
