Topic: Failed to configure Ethernet using DHCP (Read 20790 times) previous topic - next topic
Scaurus
I am in trouble because with the ethernet shield the serial monitor reply always "Failed to configure Ethernet using DHCP"
The ide is the 1.01 and the router id a d-link.
the sketch:
Code: [Select]
  DHCP-based IP printer
This sketch uses the DHCP extensions to the Ethernet library
to get an IP address via DHCP and print the address obtained.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 12 April 2011
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
  // this check is only needed on the Leonardo:
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  // print your local IP address:
  Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
zoomkat
Some test code to try:
Code: [Select]
//zoomkat 2-13-12
//DNS and DHCP-based web client test code
//for use with IDE 1.0
//open serial monitor and send an e to test
//and to see test result
//for use with W5100 based ethernet shields
//browser equivelant URL:
// http://web.comporium.net/~shb/arduino.txt
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
void setup(){
  Serial.println("DNS and DHCP-based web client test 2/13/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
    while(true);
  Serial.print("Arduino IP address: ");
    Serial.print(".");
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0"); //download text
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop(); //stop client
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
SurferTim
Do you have a memory card in the microSD slot? If so, power down the Arduino and remove the memory card, then try it again.
Scaurus
Code: [Select]
//zoomkat 2-13-12
#include <SPI.h>
void setup(){
    while(true);
    Serial.print(".");
void loop(){
  else {
Thanks for help!!
I tried this sketch but the serial monitor replies:
About the shield ethernet , it doesn't include a micro sd slot.
SurferTim
No microSD slot? Does the ethernet shield have a w5100 or enc28j60 processor? Maybe a link to that shield would help.
Scaurus
Yes mate, it's enc28j60 processor.Thanks I know about it now. So I downlaoded the library ErtherCard from https://github.com/jcw/ethercard ,but IT doesn't work too :(
I loaded this sketch:
Code: [Select]
// Ping a remote server, also uses DHCP and DNS.
// 2011-06-12 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
#include <EtherCard.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[700];
static uint32_t timer;
// called when a ping comes in (replies to it are automatic)
static void gotPinged (byte* ptr) {
  ether.printIp(">>> ping from: ", ptr);
void setup () {
  Serial.println("\n[pings]");
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println( "Failed to access Ethernet controller");
  if (!ether.dhcpSetup())
    Serial.println("DHCP failed");
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
#if 1
  // use DNS to locate the IP address we want to ping
  if (!ether.dnsLookup(PSTR("www.google.com")))
    Serial.println("DNS failed");
#else
  ether.parseIp(ether.hisip, "74.125.77.99");
#endif
  ether.printIp("SRV: ", ether.hisip);
  // call this to report others pinging us
  ether.registerPingCallback(gotPinged);
  timer = -9999999; // start timing out right away
void loop () {
  word len = ether.packetReceive(); // go receive new packets
  word pos = ether.packetLoop(len); // respond to incoming pings
  // report whenever a reply to our outgoing ping comes back
  if (len > 0 && ether.packetLoopIcmpCheckReply(ether.hisip)) {
    Serial.print("  ");
    Serial.print((micros() - timer) * 0.001, 3);
    Serial.println(" ms");
  // ping a remote server once every few seconds
  if (micros() - timer >= 5000000) {
    ether.printIp("Pinging: ", ether.hisip);
    timer = micros();
    ether.clientIcmpRequest(ether.hisip);
some problems:
1) the original sketch has 57600 baud rate , but with this value the serial monitor shows odd characters.
   so I changed 57600 to 9600 (only this one works).
2)Mostly the sketch(on the serial monitor) breaks with the first print "Ping"
3) sometimes (one time so far) it written
Failed to access Ethernet controller,
etc,,
with all values at 0.0.0.0 , clearly.
So I am in trouble again :(
FrankRadio
I build a homemade board with a 328 and the ENC and is working great.
But some examples from ethercard are not working, all most some function at the library are missing.
The example that I can't compile is this:
Code: [Select]
GetDHCPandDNS
The function that I can't found is this:
Code: [Select]
ether.dhcpExpired()
Other thing is use the reset pin from the ENC before do the DHCP procedure.
Best Regards
Frank
paulbrown
So, how does one use both the Ethernet connection on DHCP and use a card in the microSD slot? I'd like to connect to a server and write some data from that server to the card. It sounds like the microSD card makes the DHCP address assignment fail. I'm seeing this behavior on my Arduino UNO. Does anyone have any examples of code using both simultaneously?
zoomkat
DHCP and "server" may not play well together. You generally need to assign an IP address to the server so a client will have a knowm IP address to connect to. The below discussion has some server and SD card code.
http://arduino.cc/forum/index.php/topic,144675.0.html
SurferTim
You must disable one to start the other. See if this code starts the SD and w5100 ok for you.
Code: [Select]
#include <SPI.h>
#include <SD.h>
  // disable w5100 SPI while starting SD
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  Serial.print(F("Starting SD..."));
  if(!SD.begin(4)) Serial.println(F("failed"));
  else Serial.println(F("ok"));
  Serial.print(F("Starting ethernet..."));
  if(!Ethernet.begin(mac)) Serial.println(F("failed"));
  else Serial.println(Ethernet.localIP());
I used the F() function to keep the static strings in program memory.
ereihani
I have the same problem and tested all the codes you mentioned above. Besides, I connected my shield to PC and read the MAC add because I thought maybe wrong MAc add will give the DHCP config error. I have no SD card and these LEDs are on:
LINK
100M
FULLD
I always get theis error:
What should I do?
The code I test:
Code: [Select]
#include <SPI.h>
byte mac[] = {
  0x00, 0x06, 0x4F, 0x0D, 0xAC, 0xA9 };
  // start the serial library:
    for(;;)
salon2695
Hi. I am new to arduino and had decided to build a automated door lock using an ethernet shield. Initially everything worked perfectly, my ethernet shield was working and I could control an led using an app over the ethernet. However, when I made the connections for my door lock, which involves inputting a 12V-1A power supply to the door lock(I used a diode to protect my circuit), initially the shield worked but in a few seconds it lost internet connection and was giving 255.255.255.255 as an output to the command
I had by mistake used the pin 10 as a general I/O pin to control my door lock. Also, I realized later that my circuit was faulty however I don't think that caused the problem since the arduino UNO is working properly.
So now my ethernet shield returns "Failed to configure Ethernet using DHCP" whenever I run the DhcpAddressPrinter example. The state of the LEDs are:
pwr-RED
LINK-Yellow
100M-Yellow
FULLD-yellow
Coll-none
The RX blinks whenever I upload a sketch. Also, my shield is not being listed on my routers DHCP client list which it was earlier.
My doubts are:
1. Does using pin 10 as a general I/O  destroy the shield permanently?
2. If not, then what is the solution to this?
bernardocaioBR
The problem is:
you´re trying to load the code to your arduino with the ethernet shield connected on it.
First, load the code just to arduino board, without the shield plugged.
After the code is loaded, you connect the shield.
SurferTim
The problem is:
I don't need to do that. Mine works fine with the ethernet shield connected.
djberzerk
What micro-controller are you using? I had the same issue but found out that mine doesnt come with the ISP pins required to connect to the Ethernet shield. It has the slots for the ISP header but doesnt have the pins. I simply soldered pins into the ISP slots and connected directly to the associated pins on the Ethernet shield. This would be located in the back of both the Ethernet shield and the Microcontroller you are using. The connector for the pins is located on the bottom middle of the Ethernet shield. My Micro-controller is a Redboard which is basically an Arduino Uno so the ISP slots were located in the back middle part of the board labeled ISP next to the ON LED.
