Loading...
Pages: [1]   Go Down
Author Topic: CmdMessenger - QUESTIONS  (Read 444 times)
uk
Offline Offline
Newbie
Arduino rocks
View Profile
Last time I used Arduino my to create communications between message based programs and Arduino I used SimpleMessageSystem, I now see it is CmdMessenger. I am having problem uploading it to me board.
Details:
    -  My operating system is OS X 10.7.4
    - The location of the CmdMessengerExample file is :  /Documents/Arduino/hardware/libraries/CmdMessenger/CmdMessengerExample/CmdMessengerExample.pde
    - Once verifying the code I get this following error:
Quote
CmdMessengerExample.pde:-1: error: variable or field 'attach_callbacks' declared void
CmdMessengerExample.pde:-1: error: 'messengerCallbackFunction' was not declared in this scope
CmdMessengerExample.pde:-1: error: 'callbacks' was not declared in this scope
CmdMessengerExample.pde:-1: error: 'CmdMessenger' does not name a type
CmdMessengerExample.pde:-1: error: 'messengerCallbackFunction' does not name a type
CmdMessengerExample.cpp: In function 'void bens_msg()':
CmdMessengerExample.pde:-1: error: 'cmdMessenger' was not declared in this scope
CmdMessengerExample.cpp: In function 'void jerrys_base64_data()':
CmdMessengerExample.pde:-1: error: 'base64_decode' was not declared in this scope
CmdMessengerExample.pde:-1: error: 'base64_encode' was not declared in this scope
CmdMessengerExample.cpp: In function 'void arduino_ready()':
CmdMessengerExample.cpp: In function 'void unknownCmd()':
CmdMessengerExample.cpp: At global scope:
Solution?
Other questions that I had regarding this:
 - Do I have to download the SMS code, and well as Messenger before  CmdMessenger (this seems very silly but may be obvious)
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Have you downloaded the additional libraries listed in the example sketch?
Code:
// Download these into your Sketches/libraries/ folder...
// CmdMessenger library available from https://github.com/dreamcat4/cmdmessenger
#include <CmdMessenger.h>
// Base64 library available from https://github.com/adamvr/arduino-base64
#include <Base64.h>
// Streaming4 library available from http://arduiniana.org/libraries/streaming/
#include <Streaming.h>
Quote
That is the location for the IDE distribution standard libraries. Third party libraries should be stored in the libraries sub-directory of your sketchbook directory.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
The errors are compilation errors, not upload errors.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Pages: [1]   Go Up
Print
Jump to:
