Loading...
Pages: [1]   Go Down
Author Topic: Small SDCard library  (Read 2047 times)
Offline Offline
Newbie
View Profile
Hello
Is there anybody hwo knows a small library for SDCards?
My program is to big so I can't use the arduino library.
I found "filelogger" but it runs not on my arduino 1.01.
I make all changes and get no compiler errors but I only
get an initialisation error.
Can anybody help me?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The limit on the size is the fact that SD cards are written to in blocks of 512 characters at a time.
Quote
Get a Mega.
Logged
Offline Offline
Newbie
View Profile
It's not always meaningful to take the biggest prozessor  smiley
The 328 is better for normal layouts and 10kb memory only
for logging is unacceptable for my applikation.
Logged
Leeds, UK
Offline Offline
Newbie
View Profile
Exactly which library are you using? If using the SD try switching to SDfat (leaner faster and better supported).
Paul
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
You might want to look at my Fat16 library http://code.google.com/p/fat16lib/downloads/list.
It's smaller than my SdFat library but only supports FAT16 on standard SD cards.
Logged
Peoples Republic of Cantabrigia
Offline Offline
God Member
Arduino happiness
View Profile
WWW
SdFat16 works great. You can download it here
Logged
Offline Offline
Newbie
View Profile
I try the library and it works really good. Thank you very much for help.
The library save over 5 KB space.
Logged
SF Bay area
Offline Offline
Full Member
View Profile
is it correct that you can only have 2GB max partition size with fat16?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
The SD standard requires FAT16 formatted cards to be 2GB or less.
The standard requires SDHC cards, 4GB - 32GB, to be formatted FAT32.
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
fat16lib. Thanks for the library. I will try your library too. I just started using SD card and am using SD library from adafruit. I can't find manual to the library. Your library is documented with doxygen. Awesome!
With adafruit SD library, the sample write code takes 1.1KB of SRAM.
https://github.com/adafruit/SD
Logged
Offline Offline
Newbie
View Profile
Hello!
Try to get work sdfat16 with Arduino Ethernet with no luck smiley-sad init return error.
Meanwhile SD and sdfat16/32 are working good! Any ideas?
Thanks!
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Format a Standard SD card, 2GB or less with SdFotmatter https://www.sdcard.org/downloads/formatter_3/.
Change line 187 of the fat16info.pde example to:
Code:
  if (!card.init(0, 4)) {
This selects full SPI speed and pin 4 as chipselect.
Run the fat16info example and post the output.
Post your the init code for Fat16 and any output.
Logged
Offline Offline
Newbie
View Profile
Hello!
Okay, I've made some magic gestures:
1. Arduino Ethernet board with inserted microSD card (SanDisk, 2GB, formatted with SDFormatter)
2. fat16info.pde with if (!card.init(0, 4)) {
3. Result is:
Fat16 version: 20111205
FreeRam: 1261
type any character to start
card.init failed
SD error
errorCode: 1
errorData: 0
And next test:
1. Same Arduino Ethernet board with same microSD card.
2. SdInfo.pde (from sdfat16/32 library) with const uint8_t SdChipSelect = 4;
3. And result is:
SdFat version: 20121203
init time: 12 ms
Card type: SD2
Manufacturer ID: 0X3
OEM ID: SD
Product: SU02G
Version: 8.0
Serial number: 1408082784
Manufacturing date: 6/2010
cardSize: 1977.61 MB (MB = 1,000,000 bytes)
flashEraseSize: 32 blocks
eraseSingleBlock: true
SD Partition Table
part,boot,type,start,length
1,0X0,0X6,135,3858489
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
Volume is FAT16
blocksPerCluster: 64
clusterCount: 60281
freeClusters: 60281
freeSpace: 1975.29 MB (MB = 1,000,000 bytes)
fatStartBlock: 136
fatCount: 2
blocksPerFat: 236
rootDirStart: 608
dataStartBlock: 640
What I'm doing wrong with fat16 library? smiley-sad
Btw, I tried 4 Arduino boards with same result, except one which has custom bootloader with TFTP support, here is result of fat16info.pde:
FreeRam: 1261
init time: 237
Manufacturer ID: 3
OEM ID: SD
Product: SU02G
Version: 8.0
Card Size(blocks): 3862528
Partition  Table:
part,boot,type,start,size
1,0,6,135,3858489
2,0,0,0,0
3,0,0,0,0
4,0,0,0,0
FAT Volume info for partition: 1
Volume is FAT16
clusterSize: 64
clusterCount: 60281
fatCount: 2
fatSize: 236
totalBlocks: 3858489
Root Directory:
name     ext att size
Done
And same board with SdInfo.pde:
card.init failed
SD errorCode: 0X1
SD errorData: 0X0
That's really odd for me smiley-sad
Hope you could help.
Thank you!
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Looks like the Ethernet controller is causing the problem.  It's chip select is pin 10 which is also SS for 328 Arduinos.  In SdFat I set SS as an output and set it high.  SD.h also is based on SdFat so it's O.K.  In Fat16 I only make SS an output so it will be low.
To disable the Ethernet controller put his before the line with card.init().
Code:
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
I will add this to Fat16.  The Ethernet shield didn't exist when I wrote Fat16 so I didn't make SS high when it was not chip select.
Logged
Offline Offline
Newbie
View Profile
Thank you very much! It works!
Logged
Pages: [1]   Go Up
Print
Jump to:
