Topic: SHT15 problem by Data (Read 2081 times) previous topic - next topic
a760109
hi everyone
I use the sht15 sensor by Arduino , but output data feel Discontinuous ...What is the problem?
is't my data graphics.
i hope data graphics like it...
it is my code, it's simple example by sht1x
Code: [Select]
* ReadSHT1xValues
* Read temperature and humidity values from an SHT1x-series (SHT10,
* SHT11, SHT15) sensor.
* Copyright 2009 Jonathan Oxer <jon@oxer.com.au>
* www.practicalarduino.com
#include <SHT1x.h>
// Specify data and clock connections and instantiate SHT1x object
#define dataPin  15
#define clockPin 14
SHT1x sht1x(dataPin, clockPin);
   Serial.begin(38400); // Open serial connection to report values to host
   Serial.println("Starting up");
  float temp_c;
  float temp_f;
  float humidity;
  // Read values from the sensor
  temp_c = sht1x.readTemperatureC();
  temp_f = sht1x.readTemperatureF();
  humidity = sht1x.readHumidity();
  // Print the values to the serial port
  Serial.print("Temperature: ");
  Serial.print(temp_c, DEC);
  Serial.print("C / ");
  Serial.print(temp_f, DEC);
  Serial.print("F. Humidity: ");
  Serial.print(humidity);
  Serial.println("%");
  delay(2000);
Any help is appreciated! Thanks!
pylon
I would start by not converting the value to an integer when printing it:
Code: [Select]
Try:
Code: [Select]
Serial.print(temp_c);
a760109
I try
Code: [Select]
Results are as follows
Always fluctuate up and down..it is really?..the SHT15 characteristic, or my error...
pylon
I don't know this specific sensor. It has an accuracy of +/-0.3°C and a repeatability of +/-0.1°C. Looking at your values your hardware is either defect or you really have an ambient temperature that is drifting. I would try to activate the internal heater of the sensor and see if the temperature is rising about 5-10°C. If this doesn't happen, it's probably broken hardware.
a760109
hi pylon
i have seven TH15 Sensor, it always same result.
Impossible to have a defect..maybe it is not suitable...
pylon
On the picture I cannot see the pullup for the data line. Is there one on the board or have you installed one the Arduino side?
A missing pullup would explain the strange behaviour...
