Topic: Bug in SD library ?! (Read 1 time) previous topic - next topic
fs007
I'm new here, but i've a problem with the SD library (arduino 1.0.1., Mega 2560 +SD on Ethernet shield):
I want to dump the directory of an sd card as often as a user want's.
The following code e.g. work's for fine for a few (depends on how much entries exist) loops. Then less directory entries are found, at last even none !
Can anyone help ?
Code: [Select]
#include <SD.h>
    SD.begin(4);
void loop()   {
            File root = SD.open("/");
            File entry =  root.openNextFile();
            while(entry) {
              Serial.println(entry.name());
            root.close();
fs007
OK, found the answer myself:
After each openNextFile is a close() required. Otherwise too many files are obviously left open.
Example in the reference does not show this; perhaps someone could correct this.
Constantin
Good catch. Does the example page list an author? If so, would you mind contacting him/her directly with your good observation? I wouldn't count on them monitoring this forum...
fat16lib
This bug has been around for a long time.
It is now in the issues list http://code.google.com/p/arduino/issues/detail?id=832&start=300.
