Loading...
Pages: [1]   Go Down
Author Topic: controlling c# game using arduino buttons  (Read 540 times)
Offline Offline
Newbie
View Profile
i need help on interfacing my c# game with arduino, i've programmed my arduino to send a serial character to the serial port and i want my c# program to read this character and generate an event based on the character read. for example when a press a push button from my arduino the character 'E' is sent, then when this character is read from the c# program, the start button is clicked. here is my code for the arduino and c# program. i'm really confused about how serial communication works on c#, i hope somebody can help me on this.
Code:
//For Arduino
int buttonPinEnt = 2;
int buttonState1= LOW;
  pinMode(buttonPinEnt, INPUT);
void loop () {
  delay(30);
  buttonState1 = digitalRead(buttonPinEnt);
      if (buttonState1 == HIGH) {
        Serial.println('E');
//For C#
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.IO.Ports;
namespace picp
    public partial class Form1 : Form
        Form2 secondForm;
        string RxString;
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            serialPort1.PortName = "COM3";
            serialPort1.BaudRate = 9600;
            serialPort1.Open();
        private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
            RxString = serialPort1.ReadExisting();
        private void Start_Click(object sender, EventArgs e)
                secondForm = new Form2();
                secondForm.Show();
                this.Hide();
        private void Exit_Click(object sender, EventArgs e)
            Application.Exit();
Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Everything seems fine, this is missing:
Code:
            switch (serialPort1.ReadChar())
                case 'E':
                    // do something
                default:
                    // other
Logged
My homepage/blog: http://erwin.ried.cl
Offline Offline
Newbie
View Profile
doesn't seem to work, i added the code:
                case 'e':
                    Start.PerformClick();
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Useless response.
What did you read from the serial port? How do you KNOW it was an 'e'?
Logged
Offline Offline
Newbie
View Profile
since, i've programmed my arduino to send the character 'e' to the serial port, i'm assuming that when c# reads from the serial port , it will be the same character. i'm making my arduino act as keyboard, emulating the arrow keys and the enter key.
Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
The thing is you need to do something extra on your side, add a breakpoint in the receive event, or test something else. The .net debugger is very powerfull you can edit, evaluate and do almost anything while debugging to solve your issues.
Logged
Offline Offline
Newbie
View Profile
hi, i managed to make the next form appear using a background worker, now my problem is that the next form freezes while loading. also the event from the previous form is still in effect in the succeeding forms, for example in the first form i set up 'd' to exit the program, in the next form i set it up to function as down key, but it still functions as exit. am i using the background worker incorrectly.
Code:
Form2 nform;
        SerialPort port;
        char input1;
        BackgroundWorker back;
        public Form1()
            back = new BackgroundWorker();
            back.WorkerReportsProgress = true;
            back.DoWork += new DoWorkEventHandler(back_DoWork);
            back.ProgressChanged += new ProgressChangedEventHandler(back_ProgressChanged);
            back.RunWorkerCompleted += new   RunWorkerCompletedEventHandler(back_RunWorkerCompleted);
            input1 = '\0';
            port = new SerialPort("COM3", 9600, Parity.None, 8, StopBits.One);
            port.WriteTimeout = 500;
            try
                if (port.IsOpen)            //if port is open
                    port.Close();
                    port.Open();
                    port.Open();
                if (!this.back.IsBusy)
                    this.back.RunWorkerAsync(360000);
            catch
                Debug.WriteLine("The port cannot be opened!");
        void back_DoWork(object sender, DoWorkEventArgs e)
            while (true)
                try
                    //read the input
                    input1 = (char)port.ReadChar();
                    if (input1 == 'e')
                        nform = new Form2();
                        nform.Show();
                        this.Hide();
                    else if (input1 == 'x')
                        Application.exit();
                catch
        void back_ProgressChanged(object sender, ProgressChangedEventArgs e)
        void back_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
Logged
Chile
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Just don't use a background worker for the first version. You need to make it simpler. DoWork runs in a thread different than the one handling UI stuff, you can't make threads talk safely without something else (InvokeRequired and callbacks) and the worker will eat the exceptions making exe complex to debug.
If you have visual studio 2010, use IntelliTrace (set it to record all calls) to find the problems.
Logged
Pages: [1]   Go Up
Print
Jump to:
