Topic: ARM-based Arduino Due - where?? (Read 10129 times) previous topic - next topic
giantsfan3
There are certain applications I'm developing for, which could benefit greatly from the more powerful specs of a 32-bit ARM running at 96Mhz.
(I know there are alternate boards already fitting that bill, but...)
Does ANYone have any authoritative information on what is going on with the Arduino Due??
It's nearly a year delayed past what was the expected date ("by the end of 2011").
I realize of course that the engineers working on the design don't owe us anything, and frankly they might even be hard at work on this as I speak, but I'm just fascinated that there have been absolutely minimal UPDATES on the progress of this! I'm sure I am not the only one who would be interested to hear the Arduino team or anyone's update on what is going on with the release date of this.
retrolefty
Yes, it seems we get an official update maybe every 4-5 months saying it's just a couple of months away. Bottom line is that the Arduino Due is still OverDue. My bet is that the software to support the new board has been kicking their butts, as they have had hardware beta boards available to 'official' beta testers for eons now.
Lefty
Graynomad
Quote
I think that's what was getting up people's nose, the total lack of feedback. Still, as you say they don't owe us anything.
I also reckon it must be a software issue, the hardware is simple, especially if you don't try to get clever with features which I would assume they aren't.
This subject has gone very quite of late, people have either given up and bought a Pi/Beagle/whatever or they just lost interest. I suspect though that when it is finally released the interest will be rekindled.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
MichaelMeissner
With the number of low cost ARMs coming out, I suspect they've lost the momentum, and by the time Due finally comes out, it may be a case of too little too late.  Lets see, of just the ARM projects I know of:
  • Raspbery PI, two models, $25/$35, and now you can order as many as you want, runs Linux;
  • Teensy 3.0, kickstarter project that ends in 7 days (already at 800% funding), models start at $22, uses modified Arduino s/w;
  • Galgo, kickstarter project that ends in 17 days (not yet 100% funded), models start at $19, has builtin debugger, and its own development environment;
  • Mbed, two models at $45/59, uses a development environment based in the cloud
  • Beagleboard/beaglebone, $89/$149, runs Linux
Graynomad
Quote
Probably, that said I think there's plenty of scope for a "no bells and whistles" ARM board, I for one don't need or want all the crap that comes with Pi et al.
And of course anything with the "Arduino" name will have a head start.
BTW, I can't find Galgo on Kickstarter, can you provide a link?
______
Rob
giantsfan3
The simplicity is what's got me sticking with (hopes on) the Due too (as with the past Arduino boards), versus RPi and Beagleboard, etc.
And the already established Arduino user community, and the body of work that has already been done -- there are a lot more users, and lots of code, project ideas, and libraries that are already existent that one can work with and tweak to create further new things.
I agree RPi is getting there but for simpler, one-thing-at-a-time applications -- that need the horsepower but not the extra HDMI output for instance -- I'm still waiting for the Due.
Plus after using the Due board as a prototype, I can then easily use the design to make my own tailored version of it when I need to adapt things to my final application.
giantsfan3
@Graynomad:
This is Galago:
http://www.kickstarter.com/projects/kuy/galago-make-things-better?ref=category
And the Teensy 3.0 looks pretty exciting too:
http://www.kickstarter.com/projects/paulstoffregen/teensy-30-32-bit-arm-cortex-m4-usable-in-arduino-a?ref=category
Graynomad
Thanks for the Galago link.
Man it's getting so you can't keep up.
______
Rob
Jantje
I like to think it has always been like that; but I was not aware.  8)
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Osgeld
I dont even know if I want it
ARM chips are fast, but lack the grunt of the AVR, there are plenty of arm chips out there, they are not hard to work with, but when you need to nail 25ma at 5 volts you really feel their lack of micro-controller-ness
its a cpu with some embedded features, avr feels more like glue to get stuff to work
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
TonyD
There are the Olimex as well and Cutieboard
DuaneB
Quote
True, I was just looking at the Maple Mini and its limited in terms of current - which I assume makes it generally easier to kill/disturb than the AVRs.
Duane B.
rcarduino.blogspot.com
Read this
http://rcarduino.blogspot.com/2012/04/servo-problems-with-arduino-part-1.html
then watch this
http://rcarduino.blogspot.com/2012/04/servo-problems-part-2-demonstration.html
Rcarduino.blogspot.com
Graynomad
Quote
Yes you get used to being able to hang just about anything directly off an IO pin, even small relays. Not so with ARM chips.
Why is that so? It's a function of the IO and that's up to the chip manufacturer, nothing to do with the CPU core.
LPCs have a few high-current pins but not all of them, is it a limitation of the package re heat buildup?
______
Rob
MichaelMeissner
#13
Sep 11, 2012, 04:26 pm Last Edit: Sep 11, 2012, 10:08 pm by MichaelMeissner Reason: 1
Of course it depends on how it is packaged of how many pins you have for I/O.  But I was curious:
  • Tweensy 3.0 - 34 digital pins (10 shared with analog pins), 10 analog input pins with 13 bit accuracy, 10 PWM outputs, UART (3), DMA (4), i2c (1), spi (1), i2s (1)
  • Galago - 25 gpio pins, 6 analog input pins with 10 bit accuracy, 10 PWM pins (6 with high speed timers), spi (1), i2c (1), UART (1)
  • Mbed NXU LPC11U24 - 40 pins, 6 analog input pins, 8 PWM pins, spi (2), i2c (1)
  • Itead Simplecortex - 40 pins, 8 analog input, i2c (3), spi (1), UART (4), PWM (6), DAC (1)
westfw
I think output drive has a lot to do with the transistor size.  8-bit CPUs tend to be made on older fabs with big transistors.  ARMs tend to be made on modern fabs (the fab is probably less of a process than the fact that the chip layout is designed for a certain transistor size, but the same principle holds.)
The people that have any real knowledge aren't saying anything, but I'll point out that the World Maker Fair in NY is a little over a week away.  Last year's NY WMF was when Due was announced.  The spring Bay Area MF was when they solicited beta test sites...
