Topic: AS1130 First attempt - working (Read 58217 times) previous topic - next topic
Hexadec
#120
Nov 10, 2012, 03:29 pm Last Edit: Nov 10, 2012, 03:32 pm by Hexadec Reason: 1
You got it.... :smiley-mr-green:
@Rob
Hello Mr Nomad! I don't know if you've read all this thread but I've sorted out the IRQ line problem. :smiley-red:  :.
Sponge.
I'm allowed to have it 'cos it's not sharp.
graynomad
This is turning into a bigger thread than one of the famous "random number" ones :)
I don't remember what the IRQ problem was now but but good that you nailed it.
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Hexadec
That's very true...but why connect them to a resistor if they are not being used?
The statemachine of the AS1130s at Power on pulls the IRQ line to GND so it's not really floating anyway. :P
Sponge.
Hexadec
Just noticed...3830 reads.... :smiley-eek:
I wonder if anyone is actually using this chip apart from us 3.... :smiley-mr-green:
Sponge.
Hexadec
That's what I've done with my first test module...all the pullups are there but the RSTN and IRQ are not used.
I bet they're all using our ideas but are too shy to post.... ]:D ]:D
Sponge.
Hexadec
Sponge.
Hexadec
URGENT probably for you guys anyway.  :smiley-mr-green:
I've just discovered that pin18 (VDD) is NOT connected to the other VDD pins.
All the others are connected together as are the GND pins (all of 'em)
Sponge.
Hexadec
#127
Nov 11, 2012, 05:23 pm Last Edit: Nov 11, 2012, 05:35 pm by Hexadec Reason: 1
Okay
Please could you post here if you are interested in further developments with the AS1130 as I'm getting a bit frustrated with the Arduino method of development and debugging.
This is due to my lack of knowledge of the system, but I don't see any point in continuing with this if nobody is interested (I'll carry on but with a USB enabled PIC18F4550 happily on my own.)
Cheers.  ;)
Sponge.
funkyguy4000
I thought you were developing this on the PIC already.  Please continue it on your preferred platform.  I'll take care of porting it to the arduino.
Accelerate to 88 miles per hour.
graynomad
I'm interested for future reference but not currently using the chips so don't have a lot of input.
Quote
What is this, and why is a PIC different? Are you referring to the neat-looking PICkit gadgets?
______
Rob
Hexadec
:smiley-mr-green: No...I don't have any gadgets other than a PicKit3 programmer/debugger.
I'ts mostly because I don't have to stumble every time I want to change something using the MPLAB IDE. I know how it works and am familiar with it.
Also I can set break points and step through code, look at timing cycles etc. etc.
The main thing that got to me this afternoon was I couldn't figure a way of moving the data array into another file and including it in the path of the compiler. I want to get on with programming the chips...not learning to do something that I can do without effort in the CCS C or PIC18 environment and it has frustrated me for a while now that I have to scroll past 380 lines of data to get from the defines to the main loop every minute or so. I can't even move it to the end of the file because the compiler complains... :smiley-roll:
Now that I have 2 chips on the go I will have a data array which is double the size and I don't want to wear out my middle mouse button or waste more of my precious time scrolling up and down like an idiot.  :smiley-mr-green:
I will continue to learn the Arduino way...but at the moment I want to get on with my 24x11 LED matrix....
Sponge.
graynomad
Yeah, learning a new tool set is a real pain, you just want to get on with the job but keep falling over stuff because you aren't familiar with it.
The standard IDE is way too frustrating to use IMO. That said you can split your code into multiple tabs, I've not done so (because I don't use the IDE :)) but that should allow you to move all the crap at the top of the file. Try clicking on the small down arrow at the right of the tab area, that gives a menu with a "New tab" option. I assume you do that and move code across but as I said I haven't done it myself.
I feel your pain re the lack of proper debugging tools. I've been using LPCs for a while now and it's fantastic to have a real debugging environment. Maybe you should try the Visual Micro IDE, that's based on VS2008/10/12 and it's pretty nice. It does have debugging although I've only just downloaded it and haven't got it working yet.
http://www.visualmicro.com/
______
Rob
Hexadec
#132
Nov 12, 2012, 06:57 pm Last Edit: Nov 12, 2012, 09:08 pm by Hexadec Reason: 1
Thanks for the comments guys.  :D
I've managed to get the data into another file now, so I'll stick with it I think.
Aparently the compiler goes through the files and headers in alphabetical order...so you have to make sure defines and declarations are in the right place!
http://liudr.wordpress.com/2011/02/16/using-tabs-in-arduino-ide/
Oh well...still here for the duration.... ;)
PS the VS stuff looks useful.
Sponge.
Hexadec
Update:
I haven't given up... :smiley-mr-green:
I now have a board with 2 AS1130s and a 24 x 11 Matrix up and running.
Still waiting for the rest of the LEDs from China.
Sync works fine.
Interrupts now work...I'm currently coding an example.
I'll post a video and the code as soon as I have it in good shape.  ;)
Sponge.
Hexadec
#134
Nov 20, 2012, 08:52 pm Last Edit: Nov 20, 2012, 08:55 pm by Hexadec Reason: 1
Well...
Here's the video anyway...I've had so much trouble with the I2C on the Arduino, I've given up on it for the duration and written this for the PIC18F4550.  :smiley-eek-blue:
My other 500 LEDs arrived today so I'll be getting on with the soldering and finalising the 24 x 22 Matrix code on the PIC, then if I can get it reliably working I'll port it to the AVR.
http://www.youtube.com/watch?v=lSDxH89JL20&feature=youtu.be
Sorry it's the usual crappy quality but at least you get the idea.  :smiley-mr-green:
This is AS1130 #1 providing the clock for #2 and it works very well. IRQs are still a little strange but I've got a handle on it now I think. ]:)
Sponge.
