Topic: AS1130 First attempt - working (Read 58647 times) previous topic - next topic
funkyguy4000
- Idk
- Idk
- Yes
- that is just the serial baud rate between the arduino and the computer.  9600 is just a convention.  Its just your go to baud rate. The choice has no affect on the actual operation of the AS1130.
^^^^Please done forget to answer binaries questions^^^^
Once we seem to have no more questions ever coming up and have this AS1130 thing figured out completely, we'll start a new thread with concise descriptions and all that so that people can do it.  It'll still be a discussion thread but we'll try to boil it down to get all the fluff out.  We are at 15 pages and thats kind of a lot to read through when you aren't sure if you'll get your answer.
Accelerate to 88 miles per hour.
funkyguy4000
I do believe that just means that it is capable of accepting a 1MHz transmission rate in "fast mode".
What fast mode is, I don't quite know entirely.  It may be something that automatically switches over at a certain threshold in which no coding is needed.
If there is coding needed, It would be initiated in the Power-On sequence.
Hexadec
- int ack = Wire.endTransmission();
- the loop function HAS to be there...I'm just using it to start the AS1130 then pausing for a bit, then resetting, then it loops. It doesn't HAVE to. I could have changed data sets during the pause. etc.
- I already told you where to look for the answer to this and the first question. Did you look?
- why didn't you read about it BEFORE you asked the question?
Why have you STILL not read about I2C?
Here are some links:
http://dsscircuits.com/articles/arduino-i2c-master-library.html
http://www.instructables.com/id/I2C-between-Arduinos/
There are 100's more.
Sponge.
I'm allowed to have it 'cos it's not sharp.
Hexadec
#153
Nov 30, 2012, 07:40 pm Last Edit: Dec 03, 2012, 04:28 pm by Hexadec Reason: 1
Oh BTW the Arduino defaults to 100kb/s for I2C or you can set fast mode which is 400kb/s.
The AS1130 can work at 1Mb/s but you'll have to bit bang at that speed...or get a compiler that will do it automatically. eg CCS C allows:
Code: [Select]
#use I2C(master, scl=PIN_B0, sda=PIN_B1, fast=450000)
//sets the target speed to 450 KBSP
Sponge.
funkyguy4000
Ohhh okay, that makes wayyy more sense haha.
I love bit banging I2C.  SO AWESOME!  Haven't done it with the arduino platform yet though.
funkyguy4000
What details do you need? We may be able to help out.
How about this.  Link me the resources you've read and post your questions too.
I'll look through the links and answer the questions as best I can.
Hexadec
#156
Dec 03, 2012, 05:11 pm Last Edit: Dec 03, 2012, 10:02 pm by Hexadec Reason: 1
@binarygod
As far as I am concerned I posted some code which will run the AS1130 chip with 132 LEDs in the hope that other people would contribute their own efforts and we could all learn something.
This thread has turned into something completely different  :smiley-roll:
I don't have the time, inclination or skills to teach you C, C++ or any other kind of programming. The same goes for electronics.
Most of the questions you have asked have been about basic programming or electronics not about my programme or the AS1130.
Many of your questions have already been answered in the software I spent ages commenting but you have either not bothered to read or don't understand because you lack the basic knowledge.
For instance:
Quote
so where do I have to put the as_config(CONTROLREGISTER, SHUTDOWNOPENSHORT, 0b00000011); without making loops all the time?
Just makes my blood boil....I have posted code that works well that is commented AND answers this question and there was also a discussion with funkyguy about why all the setting up was done in the setup function and not in the main loop...
This is even worse:
Quote
But where can I set those 400kb/s? Or are they automatically set?
I've posted links which would answer this question, but even if I couldn't be bothered...a simple "arduino fast mode" bunged into Google brings up millions of pages. You only need to look at the first 20.
I've already suggested that you do some basic experiments with an LED matrix before you get involved with a VERY, VERY complicated chip like the AS1130...you have ignored this and continue to ask questions that have already been answered or should not need to be asked in the context of this thread. Not knowing what the setup() and loop() functions are there for is not a good starting point if you want to programme an AS1130.
You don't have a clue about the Arduino IDE and as far as I can ascertain you don't own an Arduino of any kind.
I on the other hand do have an Arduino and know enough of the basics of programming it that I can get the AS1130 working all on my own...I did this by spending a long, long time reading the datasheet and using Google. There is a mountain of information on every aspect of the Arduino freely and easily available...all you have to do is read it. There are 1000's of knowledgeable people willing to answer any questions on any subject, all you have to do is ask.
You also don't appear to have a working AS1130, an LED matrix or a compiler that allows the inclusion of header files (I find that very hard to believe) and spend lots of your time wasting my time by asking questions you should already know the answer to, not responding to the answers and then asking more questions...I've already said in this thread what I think of this, I suggest you start at post 1 and read the whole thread again.
The bottom line is...AND I have said this before to you...get an AS1130 hooked up to an LED matrix, connect your driver MCU, programme it and come back and ask SPECIFIC questions about the AS1130 which I will gladly answer. If your MCU is an Arduino and you have problems I or someone else will try to help...but basic questions about setting up things like I2C DO NOT belong in this thread.
Sponge.
funkyguy4000
Im with Hexadec on this one.
You can't work on a program or anything electronic without actually DOING it.
Electronics is logical but if you are a beginner such as yourself, its a lot to grasp so you might as well experiment.  Things may work for some reason without you knowing it.
As for my contributions with the AS1130, I'm having a hard time finding a soldering iron that actually freaking works.  I spent $50 on two soldering irons from radioshack, one never heat up, and the other wasn't sealed properly so it scorched itself.  Hate radioshack so much.
I'll update when I FINALLY get one mounted.
Hexadec
@ binarygod
Thank-you so much for your last post and for the apology.  ;)
I will spend as much time as I have trying to help you with your project and I have no wish to see you leave this thread at all.
I just hope that you understand why I posted my feelings above and why I was a bit annoyed.
Please feel that you can contribute to the thread as well when you get your matrix working...we don't want to be "liberated" from you at all!  :smiley-mr-green:
Now go on....ask me a question......I dare you..... ]:D ]:D
Take care mate, Roy
Sponge.
Hexadec
As soon as you have the hardware set up we can work through it and get your project working. I'm sure funky will be up for that as well.  :smiley-mr-green:
Spend whatever time you have on enjoying learning the basics and worry about the AS1130 when you have one.... ;)
Sponge.
Hexadec
Quote
Madness...pure madness... :smiley-mr-green: :smiley-mr-green: :smiley-mr-green:
Sponge.
Hexadec
You are quite welcome to the Arduino code which will scroll a message across a 24 x 11 matrix using movie mode...
...BUT...
a) it is not well commented.
b) it is split into 4 files
c) I have no time to explain how it works
d) I am in the process of changing it on a daily basis.
If you want it on the basis that you are entirely on your own with it and will get very little help from me then I will email it to you.  ;)
Sponge.
Hexadec
It's changed quite a bit but the principles are still the same.
PM me your email address and I'll zip it and send it.
Sponge.
Hexadec
#163
Dec 04, 2012, 07:25 pm Last Edit: Dec 04, 2012, 07:30 pm by Hexadec Reason: 1
Email sent...
In answer to your question in your PM I refer you to the following....
Quote
...BUT...
Sorry.  :.
Sponge.
Hexadec
@binarygod
I don't know what you don't understand about "you are entirely on your own with it and will get very little help from me" but you bombarding me with PMs and emails asking questions about the code is the very reason I did not want to share it in the first place!
[font=Verdana]I WILL NOT answer PMs about the code in any shape or form.[/font]
[font=Verdana]I WILL NOT answer emails about the code in any shape or form.[/font]
[font=Verdana]I MAY answer Forum posts about the code if I have the time which is VERY unlikely[/font]
If that is not now clear I will give up entirely and you will never get any code from me in the future.
Sponge.
