Southport UK
Been at it a long time...still learning every day.
« Reply #120 on: November 10, 2012, 09:29:22 am » |
You got it....  @Rob Hello Mr Nomad! I don't know if you've read all this thread but I've sorted out the IRQ line problem.
« Last Edit: November 10, 2012, 09:32:00 am by Hexadec »
Sponge. I'm allowed to have it 'cos it's not sharp.
nr Bundaberg, Australia
« Reply #121 on: November 10, 2012, 09:42:25 am » |
This is turning into a bigger thread than one of the famous "random number" ones  I don't remember what the IRQ problem was now but but good that you nailed it. _____ Rob
Southport UK
« Reply #122 on: November 10, 2012, 10:03:47 am » |
That's very true...but why connect them to a resistor if they are not being used? The statemachine of the AS1130s at Power on pulls the IRQ line to GND so it's not really floating anyway.
Southport UK
« Reply #123 on: November 10, 2012, 10:05:45 am » |
Just noticed...3830 reads....  I wonder if anyone is actually using this chip apart from us 3....
Southport UK
« Reply #124 on: November 10, 2012, 11:25:37 am » |
That's what I've done with my first test module...all the pullups are there but the RSTN and IRQ are not used. I bet they're all using our ideas but are too shy to post....
Southport UK
« Reply #125 on: November 10, 2012, 01:23:33 pm » |
It sure will...
Southport UK
« Reply #126 on: November 11, 2012, 07:10:27 am » |
URGENT probably for you guys anyway.  I've just discovered that pin18 (VDD) is NOT connected to the other VDD pins. All the others are connected together as are the GND pins (all of 'em)
Southport UK
« Reply #127 on: November 11, 2012, 11:23:20 am » |
Okay Please could you post here if you are interested in further developments with the AS1130 as I'm getting a bit frustrated with the Arduino method of development and debugging. This is due to my lack of knowledge of the system, but I don't see any point in continuing with this if nobody is interested (I'll carry on but with a USB enabled PIC18F4550 happily on my own.) Cheers.
« Last Edit: November 11, 2012, 11:35:31 am by Hexadec »
Wisconsin
I LOVE THIS STUFF!!!!
« Reply #128 on: November 11, 2012, 12:54:40 pm » |
I thought you were developing this on the PIC already. Please continue it on your preferred platform. I'll take care of porting it to the arduino.
Accelerate to 88 miles per hour.
« Reply #129 on: November 11, 2012, 03:29:45 pm » |
I'm interested for future reference but not currently using the chips so don't have a lot of input. the Arduino method of development and debugging. What is this, and why is a PIC different? Are you referring to the neat-looking PICkit gadgets? ______ Rob
Southport UK
« Reply #130 on: November 11, 2012, 03:55:17 pm » |
 No...I don't have any gadgets other than a PicKit3 programmer/debugger. I'ts mostly because I don't have to stumble every time I want to change something using the MPLAB IDE. I know how it works and am familiar with it. Also I can set break points and step through code, look at timing cycles etc. etc. The main thing that got to me this afternoon was I couldn't figure a way of moving the data array into another file and including it in the path of the compiler. I want to get on with programming the chips...not learning to do something that I can do without effort in the CCS C or PIC18 environment and it has frustrated me for a while now that I have to scroll past 380 lines of data to get from the defines to the main loop every minute or so. I can't even move it to the end of the file because the compiler complains...  Now that I have 2 chips on the go I will have a data array which is double the size and I don't want to wear out my middle mouse button or waste more of my precious time scrolling up and down like an idiot.  I will continue to learn the Arduino way...but at the moment I want to get on with my 24x11 LED matrix....
« Reply #131 on: November 11, 2012, 04:13:10 pm » |
Yeah, learning a new tool set is a real pain, you just want to get on with the job but keep falling over stuff because you aren't familiar with it. The standard IDE is way too frustrating to use IMO. That said you can split your code into multiple tabs, I've not done so (because I don't use the IDE  ) but that should allow you to move all the crap at the top of the file. Try clicking on the small down arrow at the right of the tab area, that gives a menu with a "New tab" option. I assume you do that and move code across but as I said I haven't done it myself. I feel your pain re the lack of proper debugging tools. I've been using LPCs for a while now and it's fantastic to have a real debugging environment. Maybe you should try the Visual Micro IDE, that's based on VS2008/10/12 and it's pretty nice. It does have debugging although I've only just downloaded it and haven't got it working yet. http://www.visualmicro.com/______ Rob
Southport UK
« Reply #132 on: November 12, 2012, 12:57:26 pm » |
Thanks for the comments guys.  I've managed to get the data into another file now, so I'll stick with it I think. Aparently the compiler goes through the files and headers in alphabetical order...so you have to make sure defines and declarations are in the right place! http://liudr.wordpress.com/2011/02/16/using-tabs-in-arduino-ide/Oh well...still here for the duration....  PS the VS stuff looks useful.
« Last Edit: November 12, 2012, 03:08:52 pm by Hexadec »
Southport UK
« Reply #133 on: November 16, 2012, 07:02:28 am » |
Update: I haven't given up...  I now have a board with 2 AS1130s and a 24 x 11 Matrix up and running. Still waiting for the rest of the LEDs from China. Sync works fine. Interrupts now work...I'm currently coding an example. I'll post a video and the code as soon as I have it in good shape.
Southport UK
« Reply #134 on: November 20, 2012, 02:52:42 pm » |
Well... Here's the video anyway...I've had so much trouble with the I2C on the Arduino, I've given up on it for the duration and written this for the PIC18F4550.  My other 500 LEDs arrived today so I'll be getting on with the soldering and finalising the 24 x 22 Matrix code on the PIC, then if I can get it reliably working I'll port it to the AVR. http://www.youtube.com/watch?v=lSDxH89JL20&feature=youtu.beSorry it's the usual crappy quality but at least you get the idea.  This is AS1130 #1 providing the clock for #2 and it works very well. IRQs are still a little strange but I've got a handle on it now I think. ]
« Last Edit: November 20, 2012, 02:55:14 pm by Hexadec »
