Topic: [RESOLVED] Ethernet Shield stopping at "begin" (Read 870 times) previous topic - next topic
ShaneC
Sep 10, 2012, 02:28 am Last Edit: Sep 11, 2012, 04:54 am by ShaneC Reason: 1
UPDATE: After the lack of responses here, and the utter lack of helpfulness after Binging/Googling, I took the dive and bought a new Ethernet Shield. Ran the same code, worked on the first run. QED: Previous board was in fact a dud.
I'm having difficulties getting my Arduino Ethernet Shield working. The following code prints only "Attempting..."
I've tried the examples from the IDE and those also fail to print anything through Serial. Could this be a fault in the Ethernet shield itself? Or do you see some mitigating factor?
Any input would be greatly appreciated!
Code: [Select]
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
#include <util.h>
#include <SPI.h>
// SERVER CONFIGURATION
byte server[] = { /* IP */ };
byte mac[] = { 0x90, 0xA2, 0xDB, 0x0D, 0x24, 0x2B };
EthernetClient client;
void setup(){
 Serial.begin( 9600 ); // DEBUG
 delay( 5000 );
 Serial.println( "Attempting..." );
 delay( 5000 );
 if ( Ethernet.begin( mac ) == 0 ){
   delay( 5000 );
   Serial.println( "Ethernet failed to begin." );
 }else{
   delay( 5000 );
   Serial.println( "Success!" );
void loop(){
   Serial.println( "Beginning Sequence." );
   delay( 2000 );
baum
The odd thing is that you *only* see "Attempting..."
This code:
Code: [Select]
    delay( 5000 );
  }else{
    delay( 5000 );
Should either print "Ethernet failed to begin." or "Success!", no matter what.
Maybe the code is hanging within the Ethernet.begin()...
baum
ShaneC
#2
Sep 10, 2012, 03:17 am Last Edit: Sep 10, 2012, 03:20 am by ShaneC Reason: 1
This code:
Code: [Select]
   delay( 5000 );
 }else{
   delay( 5000 );
baum
Definitely agreed (hence the title). The odd thing is if I specify an ip (as Ethernet.begin( mac, ip)) then it gets past that bit, but other problems crop up. I want to be able to do just Ethernet.begin( mac ) and get an IP from DHCP.
SurferTim
Do you have a memory card in the micro SD slot?
ShaneC
SurferTim
Are you using IDE v1.0.1?
Is the shield connected to a router that has a dhcp server?
Have you waited a couple minutes for a fail message? Mine takes about a minute.
ShaneC
Thanks for your reply!
Yes, I've tested compiling/uploading on two machines. Both are running 1.0.1.
Quote
Yes, it's plugged directly via Ethernet into the router. I've tried two separate ports, and confirmed that plugging other devices (i.e. laptops) into those ports have resulted in the device being issued an IP.
Quote
Indeed, on one test run I just let it go for about 5 minutes while I was doing something else. No further activity beyond the above.
I'm fine with purchasing a new Ethernet Shield if this one's a dud, but I'd like to confirm it's a dud before buying a new shield which does exactly the same thing!
ShaneC
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
