Loading...
Pages: [1]   Go Down
Author Topic: Changing a variable based on an analog sensor  (Read 171 times)
Offline Offline
Newbie
View Profile
Hi All,
Please can I have some help? I can't work this out, I have tried the reference pages and other examples but with no success! It's probably something very simple I'm missing
Below is my complete sketch, I am trying to change the variable "state" depending on the light levels received at the LDR. I have the serial monitor open, the LDR value is going between 850 ish when in sunlight and down to 4 when I cover it, but the state isn't changing.
Code:
int LDR_new = 0;
int state = 0;
  pinMode(12, OUTPUT);
  Serial.begin (9600);
  LDR_new = analogRead(5);
  if(LDR_new > 650)
    state = 1;
  if(LDR_new < 650)
   state = 0;
  if(state == 0)
   digitalWrite(12, LOW);
  if(state = 1);
    digitalWrite(12, HIGH);
  Serial.print ("The state value is ");
  Serial.print (state);
  Serial.print ("The LDR value is ");
  Serial.print (LDR_new);
  delay(2000);
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
  if(LDR_new > 650)
    state = 1;
  if(LDR_new < 650)
   state = 0;
A simple else block would have taken care of the less than (or equal) 650 bit.
Code:
  if(state == 0)
  if(state = 1);
Look at these two if statements. Can you see BOTH errors in the second one?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
And the third error is that there shouldn't be an "if" there at all, just an "else" .
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Of course!! Silly me! Thank you for your help, I've put in a 'else' as well smiley
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
"as well" or "instead"?
Logged
Pages: [1]   Go Up
Print
Jump to:
