Loading...
Pages: [1]   Go Down
Author Topic: Intro for -SUN7 Shield TFT Touch Screen Display Controller Shield for Arduino  (Read 727 times)
Offline Offline
Newbie
View Profile
ThaiEasyElec'sTeam is pleased to announce the SUN7 Shield - TFT Touch Screen Display Controller Shield for Arduino
http://www.thaieasyelec.net/index.php/Arduino/SUN7-Shield-TFT-Touch-Screen-Display-Controller-Shield-for-Arduino/p_225.html
https://www.youtube.com/watch?v=k84RG7wX34E
https://www.youtube.com/watch?v=bRD0NewfV3c
https://www.youtube.com/watch?v=xJ11-slCzyc
https://www.youtube.com/watch?v=D7XNpvVlGJk
SUN7 Shield was designed to allow Arduino boards to run graphic-based application using 4.3” or 7” touch screen LCD. With GUI Engine running on the shield, the user can create and configure GUI screen by screen on SUN7 Studio which is software created by ThaiEasyElec.com. The user get script folder contains script, images and sounds from SUN7 Studio and put it in the SD card to run the shield. Then all objects on the screen can be controlled by Arduino through a serial port. Moreover, the SUN7 shield contains MP3 decoder, RTC and support firmware upgrade through SD card.
GUI Script is an engine software developed by ThaiEasyElec. This script helps user to work with image rendering and touchscreen control of miniSUN7 / SUN7 TFT touchscreen LCD. GUI script is much dynamic than to draw GUI features manually using C functions. Moreover , ThaiEasyElec's Team ware developed software call "SUN7 Studio" which will help the user to design your own GUI and will generate GUI script automaticly (Please see miniSUN7's user manual at chapter 8 or video tutorial 1 / 2 for more information). For SUN7 Shield , ThaiEasyElec's Team was developed as a firmware and upload in to LPC1788 chip which ready for use with arduino . The user only plug SUN7 Shiled in to Arduino board and send/receive command via UART and use GUI Studio
Logged
Offline Offline
Newbie
View Profile
Example to display 7 inch TFT and Touch Screen for LED on/off
http://www.thaieasyelec.net/archives/Manual/SUN7_Shield/SUN7%20Shield%20Example%20Guide_V1.0EN.pdf
Logged
Offline Offline
Newbie
View Profile
If you need more information, please click link below
For all comment can place here @ arduino forum . Thank you for all opinion.
Logged
Pages: [1]   Go Up
Print
Jump to:
