Loading...
Pages: [1]   Go Down
Author Topic: analog outputs  (Read 2699 times)
Offline Offline
Newbie
View Profile
Hello,
I'm looking to produce a wave form with the arduino.
DC + AC with variable frequency, 0-10V - real analog and not PWM.
is there any arduino that enables this feature without addtional HW?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
No.
But the additional hardware can be really simple.
(You didn't mention frequency. Very important.)
« Last Edit: September 10, 2012, 08:31:36 am by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
without HW, the answer ,as far as I know, is NO.
but for DC, you can use simple LPF (i.e., RC) to generate DC from PWM.
for AC, you can also play around LPF and PWM; however, I guess, freq. will be limited > several KHz (If you are not using 490Hz default PWM), also the  wave form look rather saw tooth...
A clever summing network might be needed to add two signals.
Nahoona
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Really need to know frequency requirements, signal/noise ratio desired, resolution of output, waveforms desired, accuracy requirement, drive requirements (output impedance)...   Extra hardware is necessary, at least an external DAC and opamp amplification to 10V.  Not that simple, but certainly doable for low frequencies (audio range?).
Logged
Brighton, UK
Offline Offline
Newbie
View Profile
The recently-released Arduino Due has DACs / analog output.  You'd probably need some external level shifting / amplification as well, e.g. one op-amp.
Jim
Logged
Pages: [1]   Go Up
Print
Jump to:
