Topic: stepper motor control (Read 1 time) previous topic - next topic
Joes
hi there i have made this code up,i would like to add another function, when a switch pin goes high the stepper will return to its 0 position and when the pin goes low the stepper will return the where the pot is set to. how do we do this?
#include <Stepper.h>
// change this to the number of steps on your motor
#define STEPS 100
Stepper stepper(STEPS, 8, 9, 10, 11);
// the previous reading from the analog input
int previous = 0;
  // set the speed of the motor to 30 RPMs
  stepper.setSpeed(150);
  // get the sensor value
  int potVal = analogRead(0);
  int stpPos = map(potVal, 0, 1023, 0, 100);
  stepper.step(stpPos - previous);
  // remember the previous value of the sensor
  previous = stpPos;
sdturner
You want an if-else statement. If the input is high, undo the steps you've made, else if the input is low, go to the pot position:
#define STEPS 100
int previous = 0;
  pinMode(1, INPUT);            // This is the input pin
  // I added this if-else statement
  if (digitalRead(1) == HIGH) {
    stepper.step(-previous);
  else {
  previous = stpPos;
Joes
thanks for that but when button if high the stepper funs continuosly in the one direction
sdturner
I'm not sure about that. I've not used the stepper library so there could be some subtle issue I don't know about.
Does it work if you put constants in place of the variables?
    stepper.step(-25);
  else {
    stepper.step(25);
Joes
no just runs one way and when button go's high then go's the other way
but thinking about it, the code is runing over and over so it will keep doing it?
so to shop this i have to do somthing like this?
int ledPin =  13;    // LED connected to digital pin 13
int button = 2;      // button pin
int count = 0;       // Our blink counter
// The setup() method runs once, when the sketch starts
void setup()   {
  // initialize the digital pin as an output:
  pinMode(ledPin, OUTPUT);
  pinMode(button, INPUT);
// the loop() method runs over and over again,
// as long as the Arduino has power
  if (digitalRead(button)== HIGH)  // buttin when high
  if (count < 1) {
    digitalWrite(ledPin, HIGH);   // set the LED on
    delay(1000);                  // wait for a second
    digitalWrite(ledPin, LOW);    // set the LED off
    count++;  // add one (1) to our count
  else {
    if(count == 1) count =0;       // resetting the count
sdturner
#5
Sep 12, 2012, 12:04 am Last Edit: Sep 12, 2012, 12:10 am by sdturner Reason: 1
Doh!  :smiley-sad-blue:
or ...
    // reset the previous value to zero
    previous = 0;
  else {
    previous = stpPos;
