Topic: LED PoV (Persistance of Vision)---help (Read 2876 times) previous topic - next topic
Omnimusha
Sep 11, 2012, 02:35 am Last Edit: Sep 11, 2012, 02:39 am by Omnimusha Reason: 1
Hi, I tested this tutorial on this page http://www.kerrywong.com/2010/08/19/pov-and-pov-image-encoder/. and happy with the results. but ..... if you see the image below
creates a kind of effect envudo swirl by letters tend to deformarce, DISPONERCE in circurlar formed
I want to make it so. letters aligned, not inclined letters with repect to the ground perpencular real.
I think that the encoding of the image bytes, could make in a circular, not horizontally. I can be if I do understand.
photo 1. is encoded horizontally, ie each column represents 2bytes, total LEDs, 16 LEDs (8 * 2 = 2 bytes). barilla ie the LED is "" moves horizontally "." along the image.
that's why, "I", which creates this effect funnel, swirling letters. to be designed for a horizantal coding, while in reality, the Barilla no moves horizontally, but ciercular.
How could encode an image to bytes in a circle??, Some algorimo?, Or that otherwise could be done?
EVP
Ithink you do it by having your image/words in cartesian coordinates and then converting to polar coordinates when you send the image to the led's. The led's sort of represent polar coordinates as the spin round. Think the conversion is quite easy and available in a lot of maths books.
Omnimusha
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
