Topic: Arrays and 74HC595N (Read 983 times) previous topic - next topic
cjdelphi
void switchLED(byte led; boolean state)
  byte barray[MaxShiftRegisters]; //how many 74HC59's onboard (8 bits per byte to modify)
  //from B00000000 B00000000
  for (int n=0; n<=MaxShiftRegisters; n++)
//eg (2 of these registers control 16 leds)
//switchLED(5,TRUE); //switch LED 5 on
//switchLED(10,TRUE); //switch LED 10 on
//switchLED(5,FALSE); //switch LED 5 false
//switchLED(5,FALSE); //switch LED 5 off
so 1 should look like (B10000000,B00000000)
9 should spit out (B00000000,B10000000)
16 should be (B00000000,B00000001)
I'm not fussed about switching on say led 1, 4, 8.. i'm only ever going to be lighting 1 LED at a time in any given sequence.
Any thoughts? cheers....
PaulS
Any thoughts?
Use bitWrite() with 16 - the bit to set.
int outVal = 0;
bitWrite(outVal, 1); // 0x0001
bitWrite(outVal, 16); // 0x8000
cjdelphi
that simple? huh ... cheers i'll try it....
cjdelphi
Version 1+ requires 3 parameters.
  SomePattern();
int SetValToBin(int val)
   int n;
   for (int i=1; i<17; i++)
      bitWrite(n,i,0);
    if (i==val)
      bitWrite(n,i,1);
      return(n);
void SomePattern()
  byte hb,lb;
  int n,n2;
  for (n=1; n<17; n++)
     n2=SetValToBin(n);
     hb=highByte(n2);
     lb=lowByte(n2);
     digitalWrite(latchPin, LOW);
     shiftOut(dataPin, clockPin, MSBFIRST, lb);
     shiftOut(dataPin, clockPin, MSBFIRST, hb);
     digitalWrite(latchPin, HIGH);
     delay(800);
I'll post a video...  but essentially LED1,2,3,4,5,6,7,8 all light up 9 (does not light up) 10,11,12,13,14,15,16 all light up, then back to 1, 2,3.... until it hits 9 then no lightoutput (i checked the pins, it's not a hardware fault as B11111111 works)
Ok, small issue, for some reason, it works just fine, except the first 8 LED's come on fine, then there's a pause/gap/delay and then i expected the next row of LED's to come on, which eventually
they do except it skips the first LED....
cjdelphi
ah never mind, i got my high and low bytes mixed up.... working now thanks.
cjdelphi
   int n;
   val--; //offset
   for (int i=0; i<17; i++)
      bitWrite(n,i,0);
    if (i==val)
      bitWrite(n,i,1);
      return(n);
void SomePattern()
  byte hb,lb;
  int n,n2;
     n2=SetValToBin(n);
     lb=highByte(n2);
     hb=lowByte(n2);
     delay(800);
