Topic: 1 TRX to 2 RX on HC-SR04 (Read 2452 times) previous topic - next topic
anura92
Hi guys
Recently I bought couple HC-SR04 Ultrasonic sensor from ebay. So Yesterday I tested each one of them and they worked fine. Now I would like to test transmitting on one HC-SR04 sensor and receive the ping on another 2 HC-SR04 sensors. However I wired up the circuit below and used the code but all I get on the serial monitor was 0cm. Anyone know where i went wrong?
Code: [Select]
int TrigPin = 12;
int EchoPin1 = 11;
int EchoPin2 = 10;
  pinMode(TrigPin,OUTPUT);
  pinMode(EchoPin1,INPUT);
  pinMode(EchoPin2,INPUT);
  int distance1,duration1,distance2,duration2;
  digitalWrite(TrigPin1,HIGH);
  delayMicroseconds(11);
  digitalWrite(TrigPin1,LOW);
  duration1 = pulseIn(EchoPin1, HIGH);//EchoPin received high start counting until the receiver to the low,return to the count valu
  distance1 = duration1/29/2;//Calculating the distance  cm
  duration2 = pulseIn(EchoPin2, HIGH);//EchoPin received high start counting until the receiver to the low,return to the count valu
  distance2 = duration2/29/2;//Calculating the distance  cm
  Serial.print("Echo 1:" + distance1 + "cm" );
  Serial.print(" ");
  Serial.print("Echo 2:" + distance2 + "cm" );
RIDDICK
Hi!
what if u use the same sketch as yesterday?
then u could find out, if  it is the wiring or the sketch...
Have fun...
anura92
Yesterday i ran the example sketch for 1 ultrasonic. Its was just to test each one of them. The problem occurs when i try to use transmitter of one ultrasonic and receiver on another.
