Loading...
Pages: [1]   Go Down
Author Topic: Leonardo Serial Monitor problem  (Read 710 times)
Offline Offline
Newbie
View Profile
I received my Arduino Leonardo today. I've found an USB cable from my Samsung Galaxy to hook it up to the PC.
I've successfully uploaded the blink sketch, and I've also modified the values and re-uploaded and all seemed ok.
The problem is that when i try to print something to the Serial Monitor, nothing happens. For debugging, I've created the following sketch.
Code:
  while (!Serial) {
    digitalWrite(13,HIGH);
    digitalWrite(13,LOW);
  Serial.println("test!");
  delay(100);
  delay(300);
  delay(1);
After I upload it, the LED starts blinking 500/500 (indicating Setup function). When I open serial monitor, the LED keeps remaining ON for about 5-8 seconds, then it goes OFF for about half a second, and repeats this, until I exit the serial monitor. Then, it starts blinking rapidly. If I open serial monitor again, the LED comes back to the 5-8 seconds. And so on. In serial monitor, nothing is shown among all the test.
What could the problem be ? I'm running Windows XP SP2, Arduino 1.0.1 IDE. I've tried two USB ports, but the problem persists.
Also, when I try to send something from serial monitor, the following appears beneath the sketch:
Code:
java.io.IOException: Input/output error in writeArray
at gnu.io.RXTXPort.writeArray(Native Method)
at gnu.io.RXTXPort$SerialOutputStream.write(RXTXPort.java:1124)
at processing.app.Serial.write(Serial.java:517)
at processing.app.Serial.write(Serial.java:540)
at processing.app.SerialMonitor.send(SerialMonitor.java:200)
at processing.app.SerialMonitor.access$100(SerialMonitor.java:32)
at processing.app.SerialMonitor$4.actionPerformed(SerialMonitor.java:96)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2475)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
How can I solve those problems?
Thank you very very much in advance!
Later Edit: Tried it on a laptop with Windows 7. Works like a charm, even with the code uploaded from WinXP. Seems like Windows XP has some problems handling serial data.
« Last Edit: September 11, 2012, 06:20:14 pm by andreitdi » Logged
California
Offline Offline
God Member
View Profile
WWW
Yup.  Confirmed here on two WinXP machines.  One of the Leonardo guru's is looking into it we will see...
Logged
Offline Offline
Newbie
View Profile
I Got the very same problem on XP SP3
Any news?
Logged
Offline Offline
Newbie
View Profile
It worked for me with Windows XP SP3. Anyway, I'm using only Windows 7 now.
Try installing Windows 7, and see how it works.
Logged
Porto
Offline Offline
Newbie
View Profile
WWW
Any news?
I don't know what can be the problem, I've tested in XP SP3 and it´s working...
no idea what's happening to you...
try to update your computer or check the com port
Logged
visit my website: www.randomnerdtutorials.com
Offline Offline
Newbie
View Profile
I've already SP3, always uptodate, I think I have to format and reinstall, but I want to understand!
thanks
Sergioc.
Logged
Offline Offline
Newbie
View Profile
Hi all,
I have the very same problem here (running Arduino on a winXP SP3 laptop).
Did anyone fix it?
Logged
Offline Offline
Newbie
View Profile
Hi all,
Did anyone fix it?
Negative. I surrended and I made a bootable linux on a USB....
Sergioc.
Logged
Pages: [1]   Go Up
Print
Jump to:
