Topic: Shift Registry Question (Read 6279 times) previous topic - next topic
CrossRoads
I think you need more than a diode - you need to have the WS2801 drive a transistor to sink current thru the LEDs.
See the figure 8 discussion on pages 9 & 10 of the datasheet.
WS2801 is still powered from 5V, the LED string with current limit resistor is powered from 12V.
Computer991
#16
Oct 16, 2012, 07:11 am Last Edit: Oct 16, 2012, 07:18 am by Computer991 Reason: 1
@Osgeld:Okay thank you very much! :D
Ah okay does it need an independent transistor for each color?(RBG)
I've read through those several times I'm a bit too newbie to completely understand that.
Also is my diagram wired up correctly?
CrossRoads
Yes, transistor for each color.
Use a resistor from arduino pin to base of transistor as well - driving the base is like driving an LED to Gnd with similar voltage drop, ~0.7V.
So (5V - 0.7)/20mA = ~220 ohm resistor
What diagram?
Computer991
Oh alright thank you for your help I think ill just stick with the other solution since this would require 3 transistors.
The diagram to the other solution I was thinking of was this one https://dl.dropbox.com/u/31949989/Idea1.PNG
frollard
There are different versions of the ws2801 chip; some for 5v and some for 12v.
Daniel Garcia made a good library to use SPI EXTREMELY efficiently to drive most led strands (in the megahertz)...at the cost of some chip functionality because of how low level the code is.
http://code.google.com/p/fastSPI
Also
LadyAda made a great library for SPI/and bitbang control of ws2801 - it's not nearly as efficient but it easily outputs hundreds of frames per second on a 64 rgb strand.
https://github.com/adafruit/Adafruit-WS2801-Library
