Topic: critique programming for tcs3200 / tcs3210 color sensor. (Read 4938 times) previous topic - next topic
copiertalk
I am doing this just an as exercise on learning for my own use.
Any help or wisdom is welcomed to make it better or easier to read or understand.
TCS230 COLOR sensor from TAOS.
Written By Michael King
Copiertalk.com
Creative commons share alike.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(53, 49, 41, 43, 45, 47);
int whatcolor = 0; // what color are we testing
unsigned long   currentmillis =  millis();
unsigned long   oldmillis = millis();
int s0 = 30; // Pins for our color sensor filters
int s1 = 31;
int s2 = 32;
int s3 = 33;
int oe = 35;
int ledpin = 13;
unsigned long red = 0;
unsigned long blue = 0;
unsigned long green = 0;
unsigned long nocolor = 0;
unsigned long sensorpulse = 0;
// Setup function
// This is executed once at the start of our program
// It sets up our pins for our sensor.
  sensorpulse = 0; // I want to make sure this value starts at zero
  pinMode (s0, OUTPUT); // set up our sensor
  pinMode (s1, OUTPUT); // pins to control
  pinMode (s2, OUTPUT); // Color Filter.
  pinMode (oe,OUTPUT);
  pinMode (s3, OUTPUT);
  digitalWrite(oe,LOW);
  digitalWrite(s0,LOW); // Set scaling here.
  digitalWrite(s1,HIGH);
  digitalWrite(ledpin,HIGH);
  attachInterrupt(0, sensorisr, RISING);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  scrnsetup();
//         This is our interupt service routine.
void sensorisr ()
  sensorpulse ++; // Add 1 to our pulse count.
//          This function returns a value
// Depending on the color filter defined below.
// 1 = red filter
// 2 = blue filter
// 3 = green filter
// 4 = no color filter
unsigned long  getcolor (int color,unsigned long colormillis)
  unsigned long currentpulse;
  digitalWrite(ledpin,LOW); // turn leds on
  if (color == 1)
    digitalWrite(oe,LOW); // turn sensor on
    digitalWrite ( s2, LOW); // red
    digitalWrite ( s3, LOW);
    do
      currentpulse = sensorpulse;
    while ((millis() - colormillis)  < 250); // check for 1/4 sencond;
  if (color == 2)
    digitalWrite(oe,LOW); // Turn Sensor on
    digitalWrite ( s2, LOW); // BLue filter
    digitalWrite ( s3, HIGH);
    do
  if (color == 3)
    digitalWrite ( s2, HIGH); // greeen
    do
  if (color == 4)
    digitalWrite ( s2, HIGH); // clear filter or no color
    do
  sensorpulse=0; // reset our pulse count prior to leaving
  digitalWrite (oe,HIGH); // Turn sensor off
  // digitalWrite(ledpin,HIGH); // turn leds off if needed
  return currentpulse;
// set the static portion of our display up
// This does not change so there is no reason to display it over and over
// +++++++++++++++ set the lcd screen up ++++++++++++
void scrnsetup()
  lcd.setCursor(0,0);
  lcd.print("R:");
  lcd.setCursor(7,0);
  lcd.print("B:");
  lcd.setCursor(0,1);
  lcd.print("G:");
  lcd.setCursor(7,1);
  lcd.print("N:");
// Display our color values to the lcd display
// Position the cursor on the lcd and display the color values
void displaysensor()
  lcd.setCursor(3,0);
  lcd.print(red);
  lcd.setCursor ( 10,0);
  lcd.print(blue);
  lcd.setCursor(3,1);
  lcd.print(green);
  lcd.setCursor ( 10,1);
  lcd.print(nocolor);
//          Get the color values from our sensor
// 1 = red filter
// 2 = blue filter
// 3 = green filter
void getsensor() // Get the sensor values;
  red = getcolor (1,millis());
  blue = getcolor (2,millis());
  green = getcolor (3,millis());
  nocolor = getcolor (4,millis());
//         Our Main loop over and over again
  displaysensor();
  getsensor();
I am working towards a device to test colors on a printed page but am just starting the project and want to get the sensor output so far. Let me know what you think.
PaulS
I'd rather see all 4 sN pins set together.
Some blank lines to separate logical bits of code would be helpful, too.
Not using blank lines where not needed would be helpful, too. (The one right after setup()'s open brace is annoying.)
It might be obvious to you how that sets scaling, but it isn't obvious to anyone else.
void sensorisr ()
If you are going to use comments, and I strongly recommend that you do, stating the obvious is a waste of time.
sensorpulse (I hate names all in lower case) is used by the ISR and other functions, but is not declared volatile.
Spacesbetweenargumentsarenice.
    do
During this code, the compiler can see that sensorpulse never changes (since it is not declared volatile). As a result, this loop will never set a different value for currentpulse (camelCase was invented for a reason!), so, you might as well have used delay(250); here.
colormillis is a lousy name. Yes, the variable has something to do with time, but what, exactly? startTime would make more sense.
  if (color == 1)
  if (color == 2)
  if (color == 3)
  if (color == 4)
Is there any situation where more than one of these blocks will be executed? The else if statement should be deployed, here.
You have very similar actions in each block. A function, instead of cut and paste, would have been better.
  displaysensor();
  getsensor();
Display some values, then get some values to display. Hmmm, something's wrong with this picture.
copiertalk
Thanks paul.
I will clean up documenting a little more and work on the timer first. I will want it to check other sensor and perform other tasks while it is checking the sensor pulse values. As it is a full second elapses before the controller can do any other tasks.
I need to look up what the volitile description is for a variable. I have never used that before so its a new term to me.
Thanks again!
copiertalk
I agree
I agree. thats why I asked. see if this is easier to read and understand. I may have over documented it this time?
thats where I may have overdone the over documentation. In the data sheet and the sensor sheet there are
some inconsistancies I am still trying to get a handle on my self. bare with me a little here for the short term.
I looked into volatile and it makes sense. I have implemented it. Thanks.
easy fix although not in this version.
I would like for there to be no delay at all. I am still thinking this one over. I can increase the sensitivity of the sensor and reduce the time but in the end I would like for there to be no delay at all. That would mean handling the millis timing from the calling function rather than controling it from this function. If I increase the sensitivity it may effect millis as the program uses an interupt.
I am still thinking this over. I am probably thinking this over too much.
Better than naming it fred.
No, But that does not mean someone will not try. I will see if I can come up with a way to limit an operator error or programming error.
That is just what I was taught. Let main loop handle basic control and let your functions do the heavy lifting.
copiertalk
TCS3200 / 3210  COLOR sensor from TAOS.
Copiertalk.com
The sensor provides a pulse  depending on the value of the color filter
, frequency scaling desired as well as the output enable pin being low.
We are going to use an interupt on pin 2 to count the number of pulses in
a given amount of time. We will use the values returned to try and
and tell the color the sensor is "seeing" at the moment.
We will use these pin settings in our program to fine tume the sensor to
our needs.
s0 and s1 set the Frequency scaling
s0 = low / s1 = low is power down mode for the sensor
s0 = low / s1 = hihg 2% scale
s0 = high / s1 = low 20% scale
s0 = high / s1 = high 100% scale
s2 and s3 set the color filter of the sensor
s2 = low /  s3 = low red filter
s2 = low / s3 = high blue filter
s2 = high / s3 = low Clear or no filter
s2 = high / s3 = high green filter
Some breakout boards use an LED to illuminate the object and
we will use pin 13 to control this led on the breakout board that I
am using.
// s0 and s1 set the Frequency scaling
// s0 = low / s1 = low is power down mode for the sensor
// s0 = low / s1 = hihg 2% scale
// s0 = high / s1 = low 20% scale
// s0 = high / s1 = high 100% scale
// s2 and s3 set the color filter of the sensor
// s2 = low /  s3 = low red filter
// s2 = low / s3 = high blue filter
// s2 = high / s3 = low Clear or no filter
// s2 = high / s3 = high green filter
int s1 = 31; // and our scaling. You can use any digital pins.
int s2 = 32;
int s3 = 33;
int oe = 35;
int ledpin = 13; // pin to control sensor led on /off
// These variables are to store the pulse count returned by
// our interupt service routine. we assign them with the function call
volatile unsigned long sensorpulse = 0; // This value will be changed
// by the service routine and
// then taken and asigned to another
// variable in our program depending on the
// color filter in use
// Setup function
// It sets up our pins for our sensor, our lcd and defines our
// initial values of pin modes and outut levels.
  pinMode (s1, OUTPUT); // pins to control scaling
  pinMode (s2, OUTPUT); // set up our sensor pins
  pinMode (s3, OUTPUT); // to control color filter
  pinMode (oe,OUTPUT); // output enable pin for our color  sensor
  digitalWrite(oe,LOW); // low is enable / high is disabled
  digitalWrite(s1,HIGH); // s0 high and s1 low is 2% scale
  digitalWrite(ledpin,HIGH); // Pin to control LED on sensor if needed
  attachInterrupt(0, sensorisr, RISING); // Asign our interupt to the function and set to rising
  lcd.begin(16, 2);
  scrnsetup(); // write static portion of our lcd.
void sensorisr ()
// 1 = red filter
// 2 = blue filter
// 3 = green filter
unsigned long  getcolor (int color , unsigned long colormillis)
  if (color == 1)
    do
  if (color == 2)
    do
  if (color == 3)
    do
  if (color == 4)
    do
void scrnsetup()
  lcd.setCursor(0,0);
  lcd.print("R:");
  lcd.setCursor(7,0);
  lcd.print("B:");
  lcd.setCursor(0,1);
  lcd.print("G:");
  lcd.setCursor(7,1);
  lcd.print("N:");
  lcd.setCursor(3,0);
  lcd.print(red);
  lcd.print(blue);
  lcd.setCursor(3,1);
  lcd.print(green);
  lcd.print(nocolor);
// 1 = red filter
// 2 = blue filter
// 3 = green filter
  displaysensor();
  getsensor();
Currently what I have.
AWOL
#5
Sep 13, 2012, 03:12 am Last Edit: Sep 13, 2012, 03:32 am by AWOL Reason: 1
Are you thinking of moving the interface pins whilst the program is running?
No, I thought not, so why not make them constants, and while you're at it, make them "byte"s too?
Your get colour function has a lot of replicated code that could easily be factored up. Maybe even a switch/case instead of the "if"s.
Why pass the function the current value of millis?- it could just as well fetch it itself.
Some means of tying the constants 1,2,3,4 to the red, blue, green, clear actions would be a nice touch - maybe an enum? You could probably directly use the binary value to select the appropriate "s" pins, and eliminate the switch/case I mentioned earlier.
PaulS
Great. But, it's important to call the functions in the proper order.
  displaysensor();
  getsensor();
It just seems to me like it would make more sense to get some data then display that data. Could just be me, though.
