Loading...
Pages: [1]   Go Down
Author Topic: ARDUINO C  (Read 446 times)
Offline Offline
Full Member
View Profile
Hi all
How far is the ARDUINO C sytax from the "regular" C
 like KEIL C for example .
Th reason I ask is because I wonder about a newbe to ARDUINO
 when he learns by practice the ARDUINO C , how hard it will be to him
 when he will need to do some work with other controllers like 8051
  with KEIL compiler for example .
Thanks
Elico
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
It as far from "regular" C as "regular" C is from "regular" C++.
Logged
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
The arduino language is really c++. I worked my way thru a c/c++ tutorial nook running the examples on the arduino. The biggest things i noticed were the use of setup/loop instead of main and the lack of standard stream i/o on the arduino.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
They're in addition to main, not instead of.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Belgium
Offline Offline
Edison Member
Arduino rocks; but with my plugin it can fly rocking the world ;-)
View Profile
WWW
Quote
Actually the Arduino library contains a main.cpp which contains a main which calls setup and loop.
Code:
#include <Arduino.h>
int main(void)
init();
#if defined(USBCON)
USBDevice.attach();
#endif
setup();
for (;;) {
loop();
if (serialEventRun) serialEventRun();
return 0;
Delete the file and you have to program your own main.
Best regards
Jantje
Logged
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
