Topic: ARDUINO C (Read 1 time) previous topic - next topic
elico
Hi all
How far is the ARDUINO C sytax from the "regular" C
like KEIL C for example .
Th reason I ask is because I wonder about a newbe to ARDUINO
when he learns by practice the ARDUINO C , how hard it will be to him
when he will need to do some work with other controllers like 8051
  with KEIL compiler for example .
Thanks
Elico
Coding Badly
It as far from "regular" C as "regular" C is from "regular" C++.
bill2009
The arduino language is really c++. I worked my way thru a c/c++ tutorial nook running the examples on the arduino. The biggest things i noticed were the use of setup/loop instead of main and the lack of standard stream i/o on the arduino.
AWOL
They're in addition to main, not instead of.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Jantje
Actually the Arduino library contains a main.cpp which contains a main which calls setup and loop.
#include <Arduino.h>
int main(void)
init();
#if defined(USBCON)
USBDevice.attach();
#endif
setup();
for (;;) {
loop();
if (serialEventRun) serialEventRun();
return 0;
Delete the file and you have to program your own main.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
