Loading...
Pages: [1] 2 3   Go Down
Author Topic: ideas for creating linear movement/ general suggestions for approach please  (Read 826 times)
Offline Offline
Full Member
View Profile
What i want to ask you, is if you have maybe a better idea on how to get what i want. Maybe a cheaper/ easier way on how to do this. As this is supposed just to be an experiment those around 40€ for that motor are a bit expensive for me:
into an airtight container i want to put in a cetain fixed volume of like 40ml to create a small overpressure of like 10-20mbars.
As delivery device i thought about an syringe like this:
http://www.ebay.de/itm/100ML-Spritze-Dosierspritze-fur-Agrar-mit-Schlauch-Neu-/170867741295?pt=Infusion_Injektion&hash=item27c882d26f
i want to push and pull that syringe controlled by arduino. I doesnt matter if its possible to put in like steps between 40ml and 0ml, only 40ml pushing down directly to 0ml all the time would be perfect. What is important is repeatabilty, so it should always be those 40ml/ 4cm pushing and pulling.
For pushing and pulling i thought about a linear stepper motor like this:
http://www.ebay.de/itm/290756617726?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Maybe you know a different cheap way to put the rotating movement of a motor into the pushing in pulling.
This principle would be a possiblity too:
but id think getting a fitting gear and wheels and everything around i need would be even more complicated, but maybe you have an idea or know where to get the stuff i need.
kind regards
« Last Edit: September 13, 2012, 03:28:19 pm by lax123 » Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Why not a simple lead screw arrangement?
It could be driven by a stepper or a geared DC motor.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Full Member
View Profile
i forgot this:
hi, thanks for the hint. could you maybe show me a google picture of what you mean. as im not english i dont know what exactly you r refering too.
« Last Edit: September 13, 2012, 03:36:22 pm by lax123 » Logged
UK
Offline Offline
Tesla Member
View Profile
I think you'll manage to find a way to pressurise a sealed container, but doing it by a specific amount might be harder. Which parameter do you need to control - is it the volume displaced, or the final pressure?
Logged
Offline Offline
Full Member
View Profile
this is my plan:
the container is of known volume, inside the container is a random amount of water, but around like 2 litres container and 0,5 water. by pushing in a fixed known volume and knowing the temperature and the current atm pressure and measuring the increase in overpressure inside i should be able to calculate the volume/amount of water inside the container. for getting atm pressure inside the container it would be opened before this syringe procedure.
i thought about a small pump or peristaltic pump but i think that would not work
« Last Edit: September 13, 2012, 05:07:08 pm by lax123 » Logged
Offline Offline
Full Member
View Profile
btw, it doesnt have to be syringe and motor at all. if you can think of any other way to reach that, arduino controlled. any suggestions r welcome :-)
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Syringe idea
http://www.lynxmotion.com/p-825-vacuum-gripper-kit-with-wrist-rotate.aspx
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
UK
Offline Offline
Tesla Member
View Profile
I think I see what you're getting at now. Is 10-20 millibars worth of compression going to give you enough accuracy in your volume calculation?
Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
 I was thinking for linear movement, I would use a threaded rod connected to a stepper motor to spin the rod. You would need a bearing surface to interface the load of the threaded rod to the syringe.
 This is way too expensive but, here is an example of a linear actuator. http://progressiveautomations.com/linear-actuators-introduction-part-a-40.html
Logged
Offline Offline
Full Member
View Profile
thx,
PeterH, i hope so. As sensor i want to use mpx7002dp, 2% accuracy with zero-auto. Pressurerange -20mbar -  +20mbars. Usually i think, "stuff" has its best accuracy at the end of its range, so thats why i wanted 20mbars.
I also have an mpx5001dp, which has its range up to 100mbars, but accuracy is around 5%, maybe that would be an option too. if i have a fitting setup id experiment to see if using weight/density/temperature->volume gives same results as calculation via pressures.
cycle, i think you linked something i already have in my first post :-)
zoomkat, thx for the idea. it looks nice but also like a lot of work and hard to do, as you need the equipment, metall, tools to create something like that.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
You could maybe press the plunger with a simple cam
Logged
Offline Offline
Full Member
View Profile
whats a simple cam? sry im not english
pushing would not be sufficient, i need pulling too.  as the backpressure of 20mbar would not be enough to put the syring / or something else back to the starting position due to (i hope thats the right term, using google translate) static friction
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
A cam - like in an internal combustion engine - the thing that lifts the valves.
« Last Edit: September 14, 2012, 05:53:18 am by AWOL » Logged
UK
Offline Offline
Tesla Member
View Profile
With such small volumes and pressures, I suspect you could get away with a simple hobby servo operating a pair of bellows.
Logged
Offline Offline
Full Member
View Profile
thx,
but idk about that pair of bellows, how to "drive" it and about its "fixed" volume with its flexible parts.
so far id think zoomkats suggestion link and AWOLS leadscrew r the best suggestions i could implement.
I painted what i think would work, is that what awol was talking about with his leadscrew?
I have problems finding those parts on ebay, what i call threads is that a leadscrew?
What i call screw, how would you call that? It needs to be bigger then a regular screw as i have to attach somehow that syringe.
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
