Topic: Arduino Class "does not name a type" (Read 5309 times) previous topic - next topic
n0talentGEEK
Hello there, I am currently making a class in order to gain control over my LCD.
Here is the code:
Arduino_Marquee.h
#ifndef Arduino_Marquee_h
#define Arduino_Marquee_h
#include "Arduino.h"
#include <LiquidCrystal.h>
class Arduino_Marquee{
public:
  int max_string_length;
  int speed;
  char* text;
  Arduino_Marquee(int RS, int ENABLE, int D4, int D5, int D6, int D7, int LCD_COLLUMN, int LCD_ROW);
  void marquee_init();
  void marquee_draw();
private:
  LiquidCrystal lcd(int, int, int, int, int);
  int lcd_collumn;
  int lcd_row;
  int rs;
  int enable;
  int d4;
  int d5;
  int d6;
  int d7;
#endif
Arduino_Marquee.cpp
#include "Arduino_Marquee.h"
Arduino_Marquee::Arduino_Marquee(int RS, int ENABLE, int D4, int D5, int D6, int D7, int LCD_COLLUMN, int LCD_ROW){
  rs = RS;
  enable = ENABLE;
  d4 = D4;
  d5 = D5;
  d6 = D6;
  d7 = D7;
  lcd_collumn = LCD_COLLUMN;
  lcd_row = LCD_ROW;
void Arduino_Marquee::marquee_init(){
  lcd(rs, enable, d4, d5, d6, d7);
  lcd.begin(lcd_collumn, lcd_bar);
void Arduino_Marquee::marquee_draw(){
  for(int m = 0; m < lcd_collumn + max_string_length; m ++){
    for(int c = 0; c < lcd_row; c ++){
      for(int i = 0; i < max_string_length; i ++){
        lcd.setCursor(16 + i - m, c);
        lcd.print(text[c][i]);
    lcd.clear();
The error comes in "LiquidCrystal lcd(int, int, int, int, int);" , which is "LiquidCrystal does not name a type"
I need to control lcd inside my class.
So, I would expect some help from people here, regarding how can I make my class work.
Thank you in advance :)
nickgammon
What is in your main sketch? Is that the only error message?
More info:
nickgammon
What is the intention of this line anyway?
private:
 LiquidCrystal lcd(int, int, int, int, int);   // <---- what is this doing?
More info:
tuxduino
Member objects are declared like other variables
private:
    LiquidCrystal lcd;
The initialization of those objects happens at constructor time, with a syntax that looks like this:
: lcd(RS, ENABLE, D4, D5, D6, D7) {
... more code ...
It's ok instead to save the rows and columns values and use them later when calling lcd.begin(). The reason is begin() is a "normal" method of the LiquidCrystal class, not its constructor.
Also a note about coding style: capital letters are usually used for constants and #defined symbols...
Anyway, I'd initialize the lcd object in the main sketch and just pass a pointer to it to the Marquee class, but that's just how I'd do it... :-)
michael_x
#4
Sep 14, 2012, 11:01 am Last Edit: Sep 14, 2012, 11:13 am by michael_x Reason: 1
Why don't you just extend the LiquidCrystal class with your additional method ?
You can have a philosophical discussion  when it's appropriate to embed an object and when to derive from a base class,
IMHO here the approach class Arduino_Marquee:public LiquidCrystal{} is more appropriate.
I understand you rely on setting the public: char* text; variable prior to calling marquee_draw();,
which is intended to block your loop quite a while...   :~
Inside marquee_draw() your
       lcd.print(text[c][ i  ]);
won't compile.
Instead of fixing the syntax error, I think it's a good idea to rethink your design in general, sorry  ;)
Edit: hope it's clearer now. Fixed the  [ i ]  issue
n0talentGEEK
private:
Okay, it is actually my bad habit for not commenting the code. :(
I am using the very basic LCD with 16 columns and 2 rows.
So according to LiquidCrystal.h (int, int, int, int, int) will refers to (rs, enable, d4, d5, d6, d7) respectively.
private:
    LiquidCrystal lcd;
... more code ...
I have change the .cpp files a bit to
(int RS, int ENABLE, int D4, int D5, int D6, int D7, int LCD_COLLUMN, int LCD_ROW):lcd(RS, ENABLE, D4, D5, D6, D7)
The error returned still the same which is "LiquidCrystal does not name a type"
Actually I want make a class to make a marquee effect for an LCD, so in my humble opinion it will be  still the same if I pass the initialization of the LCD outside with the marquee looping and just put the variable inside.
won't compile.
I have tried the "extends" method in my code, when I compile it, it always return an error "Expected class name before '{' token".
About the lcd.print(text[c]); I have no problem compiling it in the previous sketch that I made, I mean firstly I made a sketch without a class, and it is works fine.
So any other idea?
I am sorry for the late reply but I am very thankful to your reply. :)
nickgammon
private:
Well, no it won't. How can it be passing in (rs, enable, d4, d5, d6, d7) when you just have (int, int, int, int, int)?
Can you post the amended code please.
More info:
tuxduino
I suspect you still don't get the difference between constructing an object and calling a method on it...
Please have a look at the code here:
http://arduino.cc/en/Tutorial/LiquidCrystal
The following line creates an object named "lcd" by calling LiquidCristal's constructor (a constructor looks like a function and has the same name as the class):
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
This line instead calls the begin() method on the previously created object "lcd":
lcd.begin(16, 2);
HTH
n0talentGEEK
private:
Oh okay I am sorry I wrongly look at the tutorial.
http://pastebin.com/GJNYS7TC The .cpp file
http://pastebin.com/ixUfRq90 The .h file
Which is now I get an error "Arduino_Marquee has not been declared"
lcd.begin(16, 2);
HTH
Well maybe you correct, I still do not get several term in programming. Well in my opinion LiquidCrystal lcd will somewhat make another object named lcd that can return all function from Liquid.
tuxduino
(btw, I didn't mean to be rude) You're right, LiquidCrystal lcd(...) will in fact "make" a LiquidCrystal object, on which you can call LiquidCrystal methods. Bottom line is, just create one lcd object at the beginning of the sketch, and use that through the whole program.
HTH
