Topic: Relay module, 5 V, where to connect? (Read 2101 times) previous topic - next topic
Certificate
Hello!
I got this 5 V Relay Module but I do not have any manual or clue where to connect it?
Digital outputs? Which pins would be the best?
All info are welceme! Thanks in advance!
Lavan
You can use any of the digital outputs, use/define the same pin in the sketch to operate the relay.  Good Luck!!!
Certificate
Thanks, Luck is just what I need, ha haa  :)
On this relay module three pins are marked S, + an -. Any knowledge of what these are?
S = signal ?
+ = Vcc
- = GND
Am I right? Any suggestions?
Lavan
Yes, you are right.  S is where you will connect your digital output.  Also you can refer link for more knowledge on relays http://arduino.cc/playground/Main/InterfacingWithHardware#Output
Certificate
Thank you, Sir! My relay problem is now solved  XD
Prepare for more questions ...
Lavan
