Topic: library issues (Read 999 times) previous topic - next topic
hadjisra
Hi, so i have tried to download a library from;http://www.wayneandlayne.com/projects/video-game-shield/download/. Now I made a library folder in sketchbook and put the library in there. Now win I open arduino it says;
The library "VideoGameShieldLibraries-2012-09-01-2" cannot be used. Libraries names can only contain basic numbers and letters.
How do i fix this?
thanks
Goofballtech
Change the name. It's telling you that you can't have dashes in the folder name.
hadjisra
hadjisra
wait I got it. Now when I try and run the nunchuck demo this error appears;
Nunchuck does not have a name
   Arduino sketch to demonstrate interfacing with a Nintendo Wii Nunchuck. It will print the nunchuck information from P1 every second, to the serial terminal at 9600 baud.
   Created by Adam Wolf and Matthew Beckler
   Wayne and Layne, LLC - http://wayneandlayne.com/projects/video-game-shield/
   Recent updates:
        August 18, 2012 - Changed file extension to .ino for Arduino 1.0
   This program is free software; you can redistribute it and/or modify
   it under the terms of the GNU General Public License as published by
   the Free Software Foundation; either version 2 of the License, or
   (at your option) any later version.
   This program is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
   GNU General Public License for more details.
   You should have received a copy of the GNU General Public License along
   with this program; if not, write to the Free Software Foundation, Inc.,
   51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
#include <i2cmaster.h>
#include <nunchuck.h>
Nunchuck nunchuck;
  nunchuck.begin(NUNCHUCK_PLAYER_1);
  nunchuck.update();
  Serial.println("Nunchuck values:");
  Serial.println("Joystick:");
  Serial.print("x: "); Serial.println(nunchuck.joy_x(), DEC);
  Serial.print("y: "); Serial.println(nunchuck.joy_y(), DEC);
  Serial.println("Accelerometer:");
  Serial.print("x: "); Serial.println(nunchuck.acc_x(), DEC);
  Serial.print("y: "); Serial.println(nunchuck.acc_y(), DEC);
  Serial.print("z: "); Serial.println(nunchuck.acc_z(), DEC);
  Serial.println("Buttons:");
  Serial.print("c: ");
  if (nunchuck.button_c())
    Serial.println("pushed");
    Serial.println("not pushed");
  if (nunchuck.button_z())
how do I fix this?
Goofballtech
That's not an error. It's an example sketch.
hadjisra
ok, well still how do I change this so i can run it?
Goofballtech
Start by posting the error you are actually getting.
hadjisra
ok here it is
nunchuck_demo:26: error: 'Nunchuck' does not name a type
nunchuck_demo.cpp: In function 'void setup()':
nunchuck_demo:30: error: 'nunchuck' was not declared in this scope
nunchuck_demo:30: error: 'NUNCHUCK_PLAYER_1' was not declared in this scope
nunchuck_demo.cpp: In function 'void loop()':
nunchuck_demo:36: error: 'nunchuck' was not declared in this scope
I think I didn't set up the library right.
Goofballtech
go here and go down to contributed libraries and see if you are doing is like this.
hadjisra
Ok yeh I did that and the library shows up in the contributed library parts but it still says the same error
Goofballtech
I just went and installed the libraries. Examples compiles fine for me.
In your libraries folder did you leave the libraries in a "VideoGame"ShielLibraries" folder or did you just move the libraries into the folder individually?
what i have is ...\arduino-1.0.1\libraries\Nunchuck
hadjisra
I moved the entire folder in. Not each individually
Goofballtech
Put them individually as i have. Mine compiles fine and your should too once the IDE can find nunchuck.h
