Loading...
Pages: 1 [2]   Go Down
Author Topic: Problema avrdude, durante upload  (Read 844 times)
Tortona
Offline Offline
God Member
View Profile
finalmente mi è arrivato il nuovo micro con il bootloader di arduino uno, l'ho montato sulla board UNO al posto d quello malfunzionante e funziona tutto perfettamente...ci mancherebbe!
quindi, seguendo la guida del prof. Menniti, ho montato il micro malfunzionante su breadboard, ho fatto tutti i collegamenti con l'arduino UNO e ho caricato lo sketch arduino ISP.
dopodichè ho fatto burn bootloader, ma mi da un errore che vi riporto sotto:
Code:
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: Recv:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done.  Thank you.
Logged
Se gommo tiene,io vince gara! Se gommo non tiene,io come bomba dentro montagna
Tortona
Offline Offline
God Member
View Profile
ops, ho scoperto che il buco della breadboard al quale collegavo i 5v di arduino non fa contatto e non si alimentava niente! in teoria adesso dovrebbe aver scritto il bootloader, provo a caricarci sopra uno sketch
EDIT: a posto! riflashando il bootloader si è ristabilito l'ordine dentro al micro e adesso c posso ricaricare gli sketch senza problemi!
« Last Edit: September 23, 2012, 08:37:14 am by cavde » Logged
Lamezia Terme
Offline Offline
Shannon Member
Le domande di chi vuol imparare rappresentano la sua sete di sapere
View Profile
WWW
mi avevi fatto preoccupare smiley-sweat smiley
Logged
Guida alla programmazione ISP e seriale dei micro ATMEL (Caricare bootloader e sketch):
http://www.michelemenniti.it/Arduino_burn_bootloader.php
Guida alla Programmazione ATmega328 noP:
http://www.michelemenniti.it/atmega328nop.html
Articoli su Elettronica In:
http://www.michelemenniti.it/elettronica_in.html
Tortona
Offline Offline
God Member
View Profile
w la tua guida!!!! smiley
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
