Topic: Arduino Rocket Ejection at Certain Altitude (Read 13212 times) previous topic - next topic
LividKiwi
Ok, I am using a arduino pro mini and a perfectflite ALT15K. I am trying to interface the altimeter to the arduino so i can get the arduino to turn a servo at 750 feet. the servo will trigger the rocket's spring parachute ejection.
I figured that I would need the altimeter to tell the arduino that when turned on, it is at 0 feet, and as it goes up, to send continous feedback on the altitude. Then at 750 feet, send the signal to turn the servo.
I am a newbie and im 16 years old, and I can use all the help i can get.
Thanks
PeterH
That approach seems reasonable. Is there something specific you're having trouble with?
LividKiwi
I dont know how to interface the alitmeter. Plus getting the arduino to do the math from the pressure from the altimeter to acutal altitiude in feet
dannable
My personal solution would be to use a BMP085 barometric pressure sensor. When you power up the Arduino it takes the current pressure as zero. Atmospheric pressure decreases by 6.0869 millibar for every 50 metres in altitude, so when the zero pressure reading subtract the current pressure reading  > 28 millibar then actuate the servo.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
justjed
The specs for this thing are pretty dicey. Nothing about data formats that I can see. It says 8 data, no parity, 1 stop, binary, 9600. Well, that's a start. But when you look at the data transfer kit, it says,
This data transfer kit incorporates level shifting and USB conversion circuitry to make the logic level signals from the altimeter compatible with standard USB ports.
Well, that might be taken to mean either 5V or 3.3V level logic, maybe TTL serial? But 8bit, 1 stop, no parity and a baud rate implies RS-232, at least to me. I think you need to dig up some full specs on the signals produced at the SIP header on the board, i.e. where the USB interface plugs into it.
I found the user's manual, and it says,
The data are transferred in a proprietary binary format with block acknowledge, so a terminal emulator program can NOT be used. Suitable MacOS and Windows compatible software is available on the PerfectFlite web site for free download. The altimeter's data connector provides and expects TTL level signals as described in the diagram below, and the mating data transfer adapter converts these to standard RS-232 serial levels.
Is there there some other way to get data from the board? Were you thinking of hacking the board to read pressure from the chip directly? Do you have this thing in hand? If so, what chips are on it?
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
LividKiwi
If I were to use a BMP085 barometric pressure sensor, then what would be a example of the code to lets say read the pressure at startup, set that at zero and actuate the parachute at 50meters. If i can get that much info, believe i could pull it off
Grumpy_Mike
How about using an accelerometer because that will tell you when the rocket is in free fall so you can trigger your spring parachute ejection when it reaches it's maximum height. That way you don't trigger it on the way up and it is safer if the rocket does not reach it's expected height.
PeterH
A microcontroller based solution doesn't strike me as the most obvious approach. Isn't there a simpler conventional solution for this? I'd have expected to find a sprung trigger that unlatches in free fall, or a fuse that is ignited by the last of the propellant, or something like that. Surely rocketeers aren't all resorting to complicated electronic solutions?
LividKiwi
The thing is I want it to eject at 750 feet, not at freefall, even if the rocket is still shooting up i want it to blow at 750 feet without using pyrotechnic charges, so im using a servo to unlatch a spring based plunger
PeterH
Oh, OK.
A pressure based altimeter would give you the resolution, I'd have thought, but in a vehicle moving at high speed you'll struggle to get a reading that is not affected by dynamic pressure. An accelerometer-based altimeter might be easier to get working in that situation. I suppose a 750' long piece of string is out of the question? :p
LividKiwi
I mean its going mach .31, not too fast and i dont think i will have a problem
aluraghi
the perfectflite has a telemetry output. i dont have the datasheet right now of the model that you are using but i remember that the minialt has an output. ive never read the output format but i think it might be a serial comunication showning the height, based on that when you download the data you get the height and the time.
regards
dannable
That depends on which library you decide to use. Basically, read the sensor in setup() to get your zero reading, then continually read it in loop(), compare / subtract one from the other and when altitude is reached actuate the servo.
kg4wsv
There's a fair amount of processing done in an altimeter, not just reading an ADC and applying a conversion formula.  I think your idea is pretty good, if it works.
The Alt15k doesn't document the interface.  If it's like the MAWD, it must be put into telemetry mode before you can expect to see any data.
If it does give you data, it's most likely converted to altitude already.
The interface is 5V TTL RS232 that you should be able to connect directly to the arduino RX line.  You can probably get by without connecting the arduino's TX line, and I'd recommend that as a flight configuration so you avoid any possibility of causing altimeter problems.
If at all possible, I'd also try to design the rocket so the motor's ejection charge can still deploy the chute, as a safety redundancy.
Good luck with TARC.
-j
justjed
Except for the part about the proprietary binary format with block acknowledge. Might be that could be hacked with a USB sniffer.
