Author Topic: array index  (Read 302 times)
Office meets Adruino
An array index usually starts with a
Is there any way to start an array with the first cell being [1] instead of
Des Moines, WA - USA
Online Online
Other than making the array length 1 greater than actually needed?  No!
Leeds, UK
Once the magic blue smoke is released, it won't go back in!
You can (sort of), but why would you want to?
Example:
byte array[10];
byte index = 1; //first index is 1.
something = array[index - 1]; //get the first element
Just for reference (useful for Serial control), you can also use ascii - assuming in this example that the array has <= 10 elements:
Example:
byte array[10];
byte index = '0'; //first element.
something = array[index - '0']; //get the element by converting ascii to decimal
« Last Edit: September 16, 2012, 12:49:19 pm by Tom Carpenter » Logged
~Tom~
I am just going to define the array with 5 elements instead of 4 and use the extra element for storing information when no leds are on.
I am playing with an rgb color sensor and I was going to store the values for each color when reflected with light from an RGB LED in the array.
1 was going to represent the red led on
2.. blue led on
3... white led on
4... green led on
it never occured to me that I may want the color values with no leds on.  I will just use the fifth element to store the color information with no leds on or the ambient light in the room.
I will just add for
0... no leds are on
Thanks for the help anyway  smiley-cool
void array(size_t i) {
  static byte ary[4];
  return ary[i-1];
If you use that function you can just replace the [ ] with ( ) and use it as a 1-indexed array.
UK
If you're really determined to do that you could declare a pointer and set it to the address of the [-1] element of your array and then dereference the pointer as if it was an array. Accessed via the pointer, all the element indices would be one higher than normal (it would go from 1 .. n rather than 0 .. n-1). I think it's a spectacularly bad idea, but it would achieve the effect you asked for.
Perhaps if you explain what you hope to achieve through this we could suggest a way to achieve it that isn't so nasty.
When I started my sketch I defined constants to represent colors the sensor I am using could represent.
1 was going to be red, 2 was going to be blue, 3 was going to be white and 4 was going to represent green.
As I have written the program I started to want to save the color values in a variable and the sensible way was to declare an array of color values. I had already used the above mothod extensively in my scetch and  I did not allow for a zero value to represent a color. I already have a bunch coded and was trying to find an easy way out is all.
I think I found a better idea.
« Last Edit: September 16, 2012, 01:59:03 pm by copiertalk » Logged
my sketch
TCS3200 / 3210  COLOR sensor from TAOS.
 Written By Michael King
 Copiertalk.com
 Creative commons share alike.
 The sensor provides a pulse  depending on the value of the color filter
 , frequency scaling desired as well as the output enable pin being low.
 We are going to use an interupt on pin 18 to count the number of pulses in
 a given amount of time. We will use the values returned to try and
 and tell the color the sensor is "seeing" at the moment.
 We will use these pin settings in our program to fine tume the sensor to
 our needs.
 s0 and s1 set the Frequency scaling
 s0 = low / s1 = low is power down mode for the sensor
 s0 = low / s1 = hihg 2% scale
 s0 = high / s1 = low 20% scale
 s0 = high / s1 = high 100% scale
 s2 and s3 set the color filter of the sensor
 s2 = low /  s3 = low red filter
 s2 = low / s3 = high blue filter
 s2 = high / s3 = low Clear or no filter
 s2 = high / s3 = high green filter
 Some breakout boards use an LED to illuminate the object and
 we will use pin 13 to control this led on the breakout board that I
 am using.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(53, 49, 41, 43, 45, 47);
unsigned long colormillis = millis(); // millis for color function
// s0 and s1 set the Frequency scaling
// s0 = low / s1 = low is power down mode for the sensor
// s0 = low / s1 = hihg 2% scale
// s0 = high / s1 = low 20% scale
// s0 = high / s1 = high 100% scale
// s2 and s3 set the color filter of the sensor
// s2 = low /  s3 = low red filter
// s2 = low / s3 = high blue filter
// s2 = high / s3 = low Clear or no filter
// s2 = high / s3 = high green filter
const int s0 = 30; // Pins for our color sensor filters
const int s1 = 31; // and our scaling. You can use any digital pins.
const int s2 = 32;
const int s3 = 33;
const int oe = 35;
const int ledpin = 13; // pin to control sensor led on /off
const int redrgbledpin = 5;
const int bluergbledpin = 7;
const int greenrgbledpin = 6;
const int ambient = 0; // constant vales to represent color
const int red = 1;
const int blue = 2;
const int nocolor = 3;
const int green = 4;
const unsigned long waittime = 25; // time to take sensor reading
// These variables are to store the pulse count returned by
// our interupt service routine. we assign them with the function call
unsigned long colorpulsecount[5];
volatile unsigned long sensorpulse = 0; // This value will be changed
// by the service routine and
// then taken and asigned to another
// variable in our program depending on the
// color filter in use
// Setup function
// This is executed once at the start of our program
// It sets up our pins for our sensor, our lcd and defines our
// initial values of pin modes and outut levels.
  sensorpulse = 0; // I want to make sure this value starts at zero
  pinMode (redrgbledpin,OUTPUT); // Set  leds
  pinMode (bluergbledpin,OUTPUT); // pinmodes as
  pinMode (greenrgbledpin,OUTPUT); // OUTPUTS
  pinMode(ledpin,OUTPUT);
  pinMode (s0, OUTPUT); // set up our sensor
  pinMode (s1, OUTPUT); // pins to control scaling
  pinMode (s2, OUTPUT); // set up our sensor pins
  pinMode (s3, OUTPUT); // to control color filter
  pinMode (oe,OUTPUT); // output enable pin for our color  sensor
  digitalWrite(oe,LOW); // low is enable / high is disabled
  digitalWrite(s0,HIGH); // Set scaling here.
  digitalWrite(s1,LOW); // s0 high and s1 low is 20% scale
  digitalWrite(ledpin,HIGH); // Pin to control LED on sensor if needed
  digitalWrite(redrgbledpin,HIGH);
  digitalWrite(bluergbledpin,HIGH);
  digitalWrite(greenrgbledpin,HIGH);
  attachInterrupt(5, sensorisr, RISING); // Asign our interupt to the function and set to rising
  lcd.begin(16, 2); // set up the LCD's number of columns and rows:
  Serial.begin(9600); // start serial
  scrnsetup(); // write static portion of our lcd.
}// end setup
//         This is our interupt service routine.
// Any time an interupt happens on the specified pin
// we increment the value of sensorpule and leave.
// Thats all we do here..
void sensorisr ()
  sensorpulse ++; // Add 1 to our pulse count.
} // end sensorisr
//          Get the color values from our sensor
// 0 = ambient color
// 1 = red filter
// 2 = blue filter
// 3 = no color filter
// 4 = green filter
void getcolorval() // Get the sensor values;
  ledcontrol (red);
  delay (250); // these will not stay here. I just want to watch the leds
  colorpulsecount[red] = getcolor (red);
  ledcontrol (blue);
  delay (250);
  colorpulsecount[blue] = getcolor (blue);
  ledcontrol (green);
  delay (250);
  colorpulsecount[nocolor] = getcolor (nocolor);
  ledcontrol (nocolor);
  delay(250);
  colorpulsecount[green] = getcolor (green);
  ledcontrol (ambient);
  delay(250);
  colorpulsecount[ambient] = getcolor (ambient);
} // end getcolorval
//         Our Main loop over and over again
  getcolorval();
  displaylcd();
  dispserial();
  delay(250); // So we can read the display
}// end loop
« Last Edit: September 16, 2012, 03:02:18 pm by copiertalk » Logged
9000 characters apparently
//          This function sets pin modes
// Depending on the color filter defined below.
// 1 = red filter
// 2 = blue filter
// 4 = green filter
void colormode ( int color)
  if (color == red)
    digitalWrite ( s2, LOW); // red
    digitalWrite ( s3, LOW);
  if (color == blue)
    digitalWrite ( s2, LOW); // BLue filter
    digitalWrite ( s3, HIGH);
  if (color == nocolor)
    digitalWrite ( s2, HIGH); // clear filter or no color
  if (color == green)
    digitalWrite ( s2, HIGH); // greeen
} // colormode
//          This function returns a value
// 0 ambient color
// 1 = red filter
// 2 = blue filter
// 4 = green filter
unsigned long  getcolor (int color)
  unsigned long colorpulse = 0; // pulse count to return
  sensorpulse = 0; // make sure sensor pulse starts at zero.
  colormillis = millis(); // record current millis
  if ((color >=1) && (color <= 4))
    colormode (color);
    colorpulse = 0; // return zero if we  ask for calor value that is not 1,2,3,4
  digitalWrite(oe,LOW); // turn sensor on
  do
    // do nothing until wait time expires
  while ((millis() - colormillis)  < waittime);
  digitalWrite (oe, HIGH); // turn sensor off.
  colorpulse = sensorpulse;
  sensorpulse = 0; // reset value of sensor pulse
  return colorpulse;
} // end getcolor
// set the static portion of our display up
// This does not change so there is no reason to display it over and over
void scrnsetup()
  lcd.setCursor(0,0);
  lcd.print("R:");
  lcd.setCursor(7,0);
  lcd.print("B:");
  lcd.setCursor(0,1);
  lcd.print("G:");
  lcd.setCursor(7,1);
  lcd.print("N:");
} // end scrnsetup
// Display our non static values to the lcd display
void displaylcd()
  lcd.setCursor(3,0);
  lcd.print("    ");
  lcd.setCursor(3,0);
  lcd.print(colorpulsecount[red]);
  lcd.setCursor ( 10,0);
  lcd.print("    ");
  lcd.print(colorpulsecount[blue]);
  lcd.setCursor(3,1);
  lcd.print("    ");
  lcd.setCursor(3,1);
  lcd.print(colorpulsecount[green]);
  lcd.setCursor ( 10,1);
  lcd.print("    ");
  lcd.print(colorpulsecount[nocolor]);
} // end displaylcd
// Here we just display the sensor value to serial minitor
// this procedure echos our sensor pulse count
// to the seial monitor.
void dispserial()
  Serial.print ( "red :");
  Serial.println (colorpulsecount[red]);
  Serial.print ( "Blue :");
  Serial.println (colorpulsecount[blue]);
  Serial.print ( "CL or NC :");
  Serial.println (colorpulsecount[nocolor]);
  Serial.print ( "Green :");
  Serial.println (colorpulsecount[green]);
  Serial.println ("-----------");
} // end dispserial
// This function toggles LEDs on depending on the value it is sent.
// 0 = ambient
// 1 = red
// 2 = blue
// 3 = no color
// 4 = green
void ledcontrol ( int color)
  if (color == 0) // turn all leds off
  if (color == 1) // turn red led on
    digitalWrite(redrgbledpin,LOW);
  if (color == 2) // turn blue led on
    digitalWrite(bluergbledpin,LOW);
  if (color == 3) // turn white led on
    digitalWrite(ledpin,LOW);
  if (color == 4) // turn green led on
    digitalWrite(greenrgbledpin,LOW);
} // end ledcontrol
copiertalk, can you send me the sketch that you are using? I am also working with that sensor.
Thanks!
Yes: point the pointer to the one unit before the start of the array. so new_array will be mapped to old_array[i-1].
Why did you decide to post a duplicate of the one posted by PeterH on september 16? Especially since OP is long gone.
