Topic: what happens if... (Read 872 times) previous topic - next topic
cjdelphi
Sep 17, 2012, 06:44 am Last Edit: Sep 17, 2012, 06:48 am by cjdelphi Reason: 1
if the ldr was connected 5v ~~~~ 1k ~~~~ ldr ~~~ A1
does the voltage divider  no longer work? A1 should act as gnd no?
CrossRoads
A1 is not connected tho.
A0 might act as ground if you used
digitalWrite(D14, LOW);
westfw
Typically, an input pin (analog or digital) will NOT "act as ground"; inputs are almost an open-circuit.
cjdelphi
digitalWrite(A1, LOW);  //as suggested should do it though....
Turning the pins to low saves a lot of work using an extra pin :) - ok cool thanks
Docedison
Also would Guarantee the circuit operation... You would Know what state it was in... just by looking at the sketch.
Doc
--> WA7EMS <--
kf2qd
Okay - I'll ask - why do you want to use A1 (or A0) as a ground?
retrolefty
I can think of a few examples where one might want to use two output pins to drive a device. Say a two color led that activates one color or the other depending on direction of current flow, or simulate a third combined color be switching the two output pins at significant clocking speed. I've used a small 20ma single coil latching relay where I could select to set or reset the relay depending on current direction, or once set or reset I could place both outputs to the same state to allow for zero current consumption for the relay. There are other applications where it might be useful to 'power' a device via two output pins, it just has to have a maximum current draw less then the output pins are rated for.
Lefty
