Author Topic: Small-run PCB assembly  (Read 2670 times)
These days, there are lots of options for getting PCB board made up, but what if you want to skip the DIY soldering and get a bunch of boards actually assembled? I appreciate this is going to require minimum quantity runs to make it even remotely economical, but what are those minimum quantities, and what are the ins-and-outs of the process?
« Last Edit: September 17, 2012, 01:13:58 pm by pico » Logged
You send the company your gerber files, and a build of materials.  If you have any other instructions on assembly also send them.  They will be able to quote you with this.  The company i talked to had a minimum of 20, but prices weren't practical until 100.  I have everything set up,  but have not yet had a fully assembled run made.  Hope this info helps, and good luck.
Boston area, metrowest
pico,
www.cbas-usa.com can do small batches of board assembly.
They won't do turnkey, you have to send them all material, and a check before they send your built board back (no paypal or visa yet), on your fed-ex account (easy to set up, with credit card billing).
They charge $350-400 (depends on board size & number of components) for stencil creation and pick & place programming. They prefer all SMD, but will do thruhole as well. Cost/board otherwise is <$10 depending on size. Send them your gerbers for a quote.
They did the blue board here for me:
'1284 with LiPo charger, Arduino style headers, Xbee socket
http://www.crossroadsfencing.com/BobuinoRev17/
Great info, thanks guys.
Bob, what size run did you do on the blue boards with CBAS?
54.
China
@pico
Here is another option for pcb assembly, you can email pcb@iteadstudio.com along with your detailed requirements.
Best regards,
Wendy
Make innovation easier!
http://imall.iteadstudio.com/
I'll certainly check that out; I didn't realise iteadstudio offered an assembly service as well.
Here is a great PCB Company that might be able to help you out if you are still looking.   http://www.semigen.net/pcb-assembly/
I used PCBCart.com
They make PCB's and also have assembly plant. Very reasonable, under $2 for an Uno type SMD board excluding components. Even with components it was reasonable.
I used PCBCart.com
Thanks for the pointer. $2 assembly per board sounds very cost effective. Does the $2 include the PCB, or is that additiona/needs to be supplied by customerl?
Seattle WA
I use a PCA Corp (http://pcacorporation.com/) in Bellevue WA. They charge $300 for the stencil (and presumably programming, although that's not broken out) and board cost is dependent on complexity. You need to negotiate to get the best prices out of them, but it's usually $5-$10 per board for all SMT in quantities 100 - 300. Through hole assembly costs more, because it requires more hand work. They aren't the cheapest, but their quality is excellent. IME, their yield even with QFNs and similarly difficult components is 100%. I haven't used them for BGA work, because I avoid BGAs like the plague.
London, UK
I use a company in china for my assembly.  They charge me about $6 per board and a setup cost of about $250.  That includes the manufacture of the PCB as well.
Good quality boards.  Shipping to the UK normally costs me about £35
The contact email is
info@junhao-cn.com
China
PCB manufacturer
Another choice from China
  Agile Circuit Co., Ltd     sales@agipcb.com
Agile Circuit Co., Ltd aims to be an effective and efficient source of PCB for electronic industry! www.agipcb.com
it's time to have a break.
I think that Elecrow is a good choice.
They don't only provide PCB fabricate service without charge extra fees for color options,
they also provide PCB Assembly service.
http://www.elecrow.com/services-c-73/prototyping-service-c-73_120/pcb-assembly-p-366.html
Hope you find this useful.
