Topic: smallest blutooth module ? (Read 2009 times) previous topic - next topic
satinssoldier
Hi guys!!
I want to build a finger ring with bluetooth inside it. Turns out the modules available are quite large.
Has anyone come across a bluetooth module that can be comfortably put inside a ring, say a module that would be less than 8mm X 8mm.
I also want an antenna (any type, normal or chip), because i finally want to interface the ring with my android phone.
Nick Gammon
Don't cross-post please. Your other post deleted.
- Moderator
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
dxw00d
Quote
In what way? Serial, or Hands-free, or A2DP, or something else?
There is a bluetooth module inside one of the earpieces in these http://www.plantronics.com/us/product/backbeat-go so they get quite small (see pic).
satinssoldier
Quote
Well, I just want to send some characters at the press of a button from the ring to the phone, just to do some simple stuff like turn on music or change songs etc. Now my problem is that I am stuck with these big bluetooth modules, which are easy to program via AT commands, but I can not fit them in the ring.
The picture you just shared, which chip is the bluetooth on that - left or right?
Can you give me some idea as to how can the bluetooth be programmed, if not for the AT commands?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
