Topic: Read/Write short to SD card (Read 860 times) previous topic - next topic
ElJosho
Hey all,
This seems like a very simple question, however I am having some trouble with it.
I wish to write a 2 byte value (unsigned short) to an SD card, and then read that same 2 byte value later on.
Saving and reading to the SD card all works fine, however I can only find how to read and write 1 byte at a time, using the basic functions such as file.read(), file.write().
Any help would be appreciated!
majenko
So, read one byte twice, and combine them?
ElJosho
Sorry I should have been more specific, I do understand how to read 2 bytes and join them together, however I can only seem to write into the file as ascii.
For example, if I wanted to write in the file the number 425, file.print() writes it in as the seperate digits '4', '2', and '5'.
Is there any way to write into the file as a complete number? Or prehaps combine the seperate digits '4', '2' and '5' into a complete number again?
Cheers!
PaulS
Quote
Sure, that's what print() does.
Quote
Sure, that's what write() does.
Quote
Sure, that's what atoi() does, once you've stored the characters in a NULL terminated array of chars.
majenko
You could either store the value as ASCII on the SD card and convert it back using atoi(), or you can use the .write() function to write individual bytes.
You can separate bytes out, and recombine them, by using simple boolean algebra - AND (&), OR (|), left shift (<<) and right shift (>>).
For example, to turn a 16-bit integer into two 8-bit bytes:
Code: [Select]
int in = 3769;
byte b1,b2;
b1 = in >> 8;
b2 = in & 8;
And to re-combine them again:
Code: [Select]
in = (b1 << 8) | b2;
ElJosho
Thanks both for your replies,
I was having trouble as atoi() would write as an integer, and I wanted a short, and file.write() would only let me write 1 byte of a 2 byte number.
But I will use the method of splitting the number into seperate bytes before writing it, thanks!
majenko
The Arduino uses 16-bit integers.  That's the same as a short.
ElJosho
Well damn. I have no idea how I didn't already know that, too used to C I guess!
Thanks a bunch, thats some important info!
majenko
The Arduino is programmed in C.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
