Topic: Problem with buffers after EEPROM read (Read 1 time) previous topic - next topic
harrysfrags
I'm having trouble with a buffer being partially populated with data from an EEPROM read.  I have two buffers (Lobuffer and Hibuffer) with hold a time in the format (hh:mm[a or p]m).  I can read the data from EEPROM into Hibuffer and it works correctly.  Then I read the data into Lobuffer.  That works correctly but it also appends the data (or part of it) onto the end of the Hibuffer string.
Example:
Hibuffer after read from EEPROM:  12:05am (this is correct)
Lobuffer after read from EEPROM:  5:11am (this is correct)
but now the value in Hibuffer is : 12:05am:11am
harrysfrags
Here are parts of the sketch:
Code: [Select]
#include <EEPROM.h>
char Hibuffer[6];
char Lobuffer[6];
// EEPROM map
int HiTempAddr = 0;        // 0 - 3
int HiBufferAddr = 4;      // 4 - 10
int LoTempAddr =  11;      // 11 - 14
int LoBufferAddr = 15;     // 15 - 21
int HistHiTempAddr = 22;   // 22 - 25
int HistHiBufferAddr = 26; // 26 - 41
int HistLoTempAddr = 42;   // 42 - 45
int HistLoBufferAddr = 46; // 46 - 51
  lcd.begin(nColumns,nRows);
  Wire.begin();
  watchdogSetup();
  ReadFromEEPROM();
    getTemp();
// Convert decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// display high temp
void DisplayHighTemp()
    // print high temp and time of high
    lcd.setCursor(0,1);
    lcd.print("Hi ");
    lcd.print(floatToString(buffer4,HiTemp,1));  // convert temp from float to string and print it
    lcd.print(" ");
    lcd.print(Hibuffer);
// display low temp
void DisplayLowTemp()
    // print low temp and time of low
    lcd.setCursor(0,2);
    lcd.print("Lo ");
    lcd.print(floatToString(buffer4,LoTemp,1));  // convert temp from float to string and print it
    lcd.print(" ");
    lcd.print(Lobuffer);
// read float from eeprom
float eepromReadFloat(int address){
   union u_tag {
     byte b[4];
     float fval;
   } u;
   u.b[0] = EEPROM.read(address);
   u.b[1] = EEPROM.read(address+1);
   u.b[2] = EEPROM.read(address+2);
   u.b[3] = EEPROM.read(address+3);
   return u.fval;
// read int from eeprom
int eepromReadInt(int address){
   int value = 0x0000;
   value = value | (EEPROM.read(address) << 8);
   value = value | EEPROM.read(address+1);
   return value;
// read string from eeprom
void eepromReadString(int address , char string[], int len)
for (int i=0; i <= len; i++)
  {string[i] = EEPROM.read(address);
  address++;
// write int to eeprom
void eepromWriteInt(int address, int value){
   EEPROM.write(address, (value >> 8) & 0xFF );
   EEPROM.write(address+1, value & 0xFF);
// write float to eeprom
void eepromWriteFloat(int address, float value){
   union u_tag {
     byte b[4];
     float fval;
   } u;
   u.fval=value;
   EEPROM.write(address  , u.b[0]);
   EEPROM.write(address+1, u.b[1]);
   EEPROM.write(address+2, u.b[2]);
   EEPROM.write(address+3, u.b[3]);
// write string to eeprom
void eepromWriteString(byte address , char string[], int len)
for (int i=0; i <= len; i++){EEPROM.write( address , string[i]);
  address++;
// get temp
void getTemp()
  if ( !ds.search(addr)) {
    ds.reset_search();
    //Serial.print("bad address");
    return;
if ( OneWire::crc8( addr, 7) != addr[7]) {
  Serial.print("CRC is not valid!\n");
  return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1);         // start conversion, with parasite power on at the end
  delay(750);     // maybe 750ms is enough, maybe not
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
  LowByte = data[0];
  HighByte = data[1];
  TReading = (HighByte << 8) + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1; // 2's comp
  Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
  //get the whole and fraction in Celcius
  Whole = Tc_100 / 100;  // separate off the whole and fractional portions
  Fract = Tc_100 % 100;
  temp=(data[1]<<8)+data[0];//take the two bytes from the response relating to temperature
  temp=temp/16;//divide by 16 to get pure celcius readout
  temp=temp*1.8+32; // convert to Fahrenheit
  lcd.setCursor(0,0);
  lcd.print("Temp: ");
  lcd.print(floatToString(buffer4,temp,1));  // convert temp from float to string and print it
  lcd.print(" ");  //blank out trailing character from previous post
  // compare to high and low
  if (temp > HiTemp)  // update high temp
    HiTemp = temp;
    if (DisplayHour < 10)
      sprintf(Hibuffer, "%01d:%02d%c%c%c",DisplayHour, minute, ampm, 'm', ' ');
      sprintf(Hibuffer, "%02d:%02d%c%c%c",DisplayHour, minute, ampm, 'm', ' ');
    // save it to EEPROM
    eepromWriteFloat(HiTempAddr, HiTemp);
    eepromWriteString(HiBufferAddr, Hibuffer, 6);
    DisplayHighTemp();
  if (temp > HistHiTemp)  // update high temp
    HistHiTemp = temp;
      sprintf(buffer16, "%01d:%02d%c%c%c%d/%d/%d",DisplayHour, minute, ampm, 'm', ' ', month, dayOfMonth, year);
      sprintf(buffer16, "%02d:%02d%c%c%c%d/%d/%d",DisplayHour, minute, ampm, 'm', ' ', month, dayOfMonth, year);
    eepromWriteFloat(HistHiTempAddr, HistHiTemp);
    eepromWriteString(HistHiBufferAddr, buffer16, 16);
  if (temp < LoTemp)  // update low temp
    LoTemp = temp;
      sprintf(Lobuffer, "%01d:%02d%c%c%c",DisplayHour, minute, ampm, 'm', ' ');
      sprintf(Lobuffer, "%02d:%02d%c%c%c",DisplayHour, minute, ampm, 'm', ' ');
    eepromWriteFloat(LoTempAddr, LoTemp);
    eepromWriteString(LoBufferAddr, Lobuffer, 6);
    DisplayLowTemp();
// load variables from EEPROM @ startup
void ReadFromEEPROM()
  HiTemp = eepromReadFloat(HiTempAddr);
  eepromReadString(HiBufferAddr, Hibuffer, 6);
  DisplayHighTemp();
  LoTemp = eepromReadFloat(LoTempAddr);
  eepromReadString(LoBufferAddr, Lobuffer, 6);
  DisplayLowTemp();
  HistHiTemp = eepromReadFloat(HistHiTempAddr);
  HistLoTemp = eepromReadFloat(HistLoTempAddr);
void watchdogSetup()
  cli();  // disable all interrupts
  wdt_reset(); // reset the WDT timer
  MCUSR &= ~(1<<WDRF);  // because the data sheet said to
  WDTCSR configuration:
  WDIE = 1 :Interrupt Enable
  WDE = 1  :Reset Enable - I won't be using this on the 2560
  WDP3 = 0 :For 1000ms Time-out
  WDP2 = 1 :bit pattern is
  WDP1 = 1 :0110  change this for a different
  WDP0 = 0 :timeout period.
  // Enter Watchdog Configuration mode:
  WDTCSR = (1<<WDCE) | (1<<WDE);
  // Set Watchdog settings: interrupte enable, 0110 for timer
  WDTCSR = (1<<WDIE) | (0<<WDP3) | (1<<WDP2) | (1<<WDP1) | (0<<WDP0);
  sei();
This is only the parts of the code that pertains to the problem that I'm having.  The whole sketch is 20174 bytes right now.  Could I have a memory overflow?
PaulS
Quote
Not interested. Post ALL of the sketch.
PaulS
Code: [Select]
%01d requires one space in the array.
: requires one space in the array.
%02d requires two spaces in the array.
%c%c%c requires three spaces in the array.
The terminating NULL requires on space in the array.
That's 8 of the 6 spaces...
harrysfrags
When I try to post the whole sketch I get the error: The message exceeds the maximum allowed length (9500 characters).
PaulS
Quote
Nothing to stop you from attaching it to your post, though. Select the Additional Options... link (yes, I know it doesn't look like a link), and then the Browse button.
harrysfrags
Thanx, here it is.
PaulS
Doesn't look like you've read replay #3 (or done anything about it...).
harrysfrags
If you mean the size of the buffer; I figure that
char Hibuffer[6];
is 7 bytes long (starting @ 0); so 10:36am would fit.  You mentioned a NULL byte.  Do I need to added that and if so how.
My problem now is not reading the correct data and putting it in the correct buffer, but also appending it to the data in the previous buffer.
PaulS
Quote
char Hibuffer[6];
is 7 bytes long
The value in the brackets is the number of elements, not the upper index.
Quote
No, it won't.
Quote
No. sprintf() is doing that for you. But, you must provide room in the array for it. The array sizes must both be a minimum of 8.
harrysfrags
Thanx, I'll give that a shot!
Would that have anything to do with appending to another buffer?
PaulS
Quote
Of course, because you are writing outside the bounds of your array(s).
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
